Question about Dell 3100cn Laser Printer
Dell 3100CN Error Message
I am receiving a 004-324 restart printer error message on my front panel; I have checked all connections, turned off everything, unplugged everything and I continue to receive the same message.............HELP!
  • 3 more comments
  • Anonymous Nov 14, 2007
    016-370
  • john_george2 Jun 27, 2008
    I have a dell 3100cn printer and it won't print. it just stops and gives error code
    004-332. Please email me.
  • CaribbeanBlu Jul 06, 2008
    I am having the same problem (004-332 Restart Printer) and have no solution...
  • Anonymous Jul 07, 2008
    clean all color toner and clean all the sensor still send problem power on and power off about 10 time sen problem
  • carleysmma Jul 20, 2008
    printer always gives error code and saysto restart
I got the same problem, i changed the drum cartridge and printer is fine now.
Posted on Jul 14, 2008
The MCU (main control unit) board is dead.
Posted on Oct 29, 2007
I am a publisher here in Seattle printing full color books with this machine and I have just gotten the same message- Does anyone have a solution- I have Googled and checked everything... Now, this happened to me a few months ago and I pulled out the drum and sprayed it with air, replaced it and it worked fine for about two months- now I get the error again- does this help in the problem solving?
Posted on Nov 27, 2006
Error code 016-370 Restart printer If problem
Error code: 016-370
This is yet another error message asking you to restart the printer. You need to switch off the printer and then connect it via the USB cable. Press the hold and cancel buttons simultaneously. Then power on the printer again. On your LCD display you should typically see a message saying 'ready for download mode'. You will then need to initialize the firmware update process. LCD will change to the writing mode. 10 minutes later you will be prompted to start the printer again.
The firmware is available here:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R148843&SystemID=PRN_LSR_3100CN&servicetag=&os=WLH&osl=en&deviceid=6673&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=40&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=197745
May 02, 2011 | Dell 3100cn Laser Printer
I'm getting the following error: Dell 3100cn Laser Printer error 004 332 problems
Try restarting your printer, if this does not help make sure that the toner cartridges are set in properly and locked in place.
Mar 28, 2011 | Dell 3100cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Get error message "004-321 Restart printer" Have tried everything.
this is a 'reseat drum' message. If you do that and make sure all is clean then restart it should be fine.
Sep 12, 2010 | Dell 3100cn Laser Printer
Dell 3130cn gone down with repeating 016-370 Error...
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer. Please let me know the results.
Jun 28, 2010 | Dell 3100cn Laser Printer
We are getting error code 004-332 Restart Printer on our Dell 3100cn printer. We have tried unplugging and restarting print spooler but it still come up witht message when we try to print
Hi
This error code on Dell 3100CN occurs when toner cartridges are not seated properly and/or are not properly locked in. Turn off the printer and unplug it. Now, you need to open the front door and pull out the drum. Try moving the carousel and check if it moves freely. While moving the carousel back and forth try adjusting the cartridges. try to unlock the cartridges and lock them again.
Now turn off the printer and turn it on after 1-2 min.s.
Daniel Scott
Jun 24, 2010 | Dell 3100cn Laser Printer
Dell 3000cn error message 016-310 restart Printer. I have tried removing the drum and turning till metal shows, cleaning all components and pulling and reinstalling plugs on the mother board but no luck....
Turn off the printer, and then hold down the "Menu" button on the front of the printer, and then turn on the power to the printer.
You should see the "Init Password" message on the front panel, and just choose No to not init the password.
Jan 25, 2010 | Dell 3100cn Laser Printer
Dell printer
Error code: 004-332
Aug 26, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
801 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
