Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam 788 how do i transfer a track from a cd onto my tascam so i can mix it down. its a tascam 788
    Novelist:
  • 189 Answers
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Posted on Oct 23, 2008
Can't figure out how to mix down tracks to stero master on 2488 mk 2
Your owners manual can be found at manualslib.com by searching your model number and choosing manualslib under the heading TASCAM 2488MKII OWNER'S MANUAL Pdf Download.
Tascam has a help line at 323-727-7617. If you haven't done your homework in deciphering the users manual, I would not call them. Their service is free, but their on phone time for help is limited and they can be quite surly.
Dec 16, 2017 | Tascam Audio Players & Recorders
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
How to record with Multi-effects feature on Tascam DP 01
I'm not familiar with the Tascam DP-01 but many multi-track recorders don't commit effects to the track until the mixdown phase. The thinking being that you cannot eliminate a "bad choice" effect once it's down to tape (old school term) and so they allow adding the audio tweaks at the final stages of recording. Here they hope you can appreciate the entire mix and then decide what sweetners to add.
Feb 21, 2013 | Tascam Audio Players & Recorders
How to download from the Tascam 788 to the CD Burner?
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Chapter 8
Feb 04, 2011 | Tascam 2488 Portastudio Multitrack...
Want to copy files from Tascam 788 to IMAC's Garage Band
The problem is thus. You have a multitrack recording saved in a format that your portastudio recognizes and you want to use it on your imac. If you can copy the file to the imac as a file, a translator, if one is available, will make it usable by the mac. You won't be able to play it and record on the imac because maintaining the recording as multitrack would require one output from the portastudio and one input on the imac for each recorded track.
Bummer dude. The kluge method would be to play/record 2 tracks at a time (or however many outputs and inputs are available) and hope for some semblance of time alignment, after which you can fine tune it and then start your editing.
Apr 09, 2009 | Tascam Electronics - Others
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
DP-01FX/CD
Unfortunately it's pretty much impossible to get a recording to sound like anything produced commercially these days without using lots of compression. Your burned CD problems might be the result of a faulty burner on your DP01-FX/CD. I have a 2488 and I still export all my mastered songs as wav files and burn them onto disc using my PC just because of the flexibility on the PC and you can control settings better which can cause disc burning problems (not to mention that the burner is newer and faster on my PC).
If you don't want to work on a PC you could look into replacing the burner in your Tascam. It is similar to replacing a PC's burner and the either the Tascam site and/or the Tascam Forum should be able to provide you with the specs and a list of compatible CD burners.
To get the final product to sound louder you could invest in an external compressor (a good used one should run you less than $100). You'll have to use the DP01's send loops to route a bounce of the stereo mix out to the compressor and then route the result back into the DP01 inputs and record on a couple of free tracks.
Hope this helps.
Cheers
bd.
Oct 14, 2008 | Tascam DP01 All-In-One Recording Package...
Could you please tell me the simplest way to record a backing track off a cd onto the hard drive of the Tascam DP-01FX/CD and then add vocal and other percussion onto this track. I bought the unit...
Just review the manual guide,everything is there; in how to record.
If happens if you don't have it,just click below..
Sponsored Links Tascam Manuals on Retrevo
Free download of manuals from the
largest collection on the web
www.retrevo.com/Tascam-manuals
Aug 10, 2008 | Tascam Audio Players & Recorders
Burn CDs from Tascam US-122L
The answer is yes, but it may not work as simply as you think. You can't just save your Cubase file / mix and then send it to your recorder. You'll want to render down the song you have to one stereo .wav file and send that to burner as a wav file. (That's the quick way). Another option is to render each file you have seperately so acoustic guitar, bass, vocal, etc are all seperate tracks. So the answer is yes, a .wav file is the format for audio cds. You'll record your seperate tracks and then you'll have to mix down, render, or export them when you are done. In Cubase, use "export".
Feb 07, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Tascam 2488 Portastudio Multitrack Recorder System Logo
393 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
