Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Posted on Jul 02, 2006
Mar 30, 2015 | GE Washing Machines
Nov 14, 2017 | Estate TAWX700JQ Top Load Washer
Feb 17, 2018 | Jackson JP-24B Built-in Dishwasher
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Jul 16, 2009 | Maytag MDB6650A Built-in Dishwasher
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Jan 04, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
483 people viewed this question
does not run cycle after water fills. timer works
fills up and runs thru cycle but water dose not drain
