Question about HP Officejet Pro L7680 All-In-One Printer
HP 7680 paper jam
The feeder for the fax seems to load the paper in slightly crooked and it has ended up as a jammed fax. There is no way to clear the paper jam! HP has already sent us a replacement printer, which promptly did the same thing again! Any solution to clearing a paper jam?
  • 11 more comments
  • decelaxmundi Nov 15, 2008
    I am ready to shoot it. There is no paper in the printer and it still says paper jam
  • Anonymous Nov 19, 2008
    Spoke with HP. Went through all the 1st level support to get a recommendation to clean rollers with distilled water. Didn't fix it.
    I am stuck with a all-in-one-sans-multipage-fax-capability-because-the-feeder-is-broken-printer
  • gremmy Nov 27, 2008
    paper jammed
  • willie peter Dec 02, 2008
    Same deal! The paper gets loaded into the feeder slightly off kilter and won't complete feeding until I lift the cover. Earlier a piece of paper got jambed in the feeder and came out in pieces but I put the sheet back together to make sure I got it all out. There were no pieces left in the machine. Think maybe I messed up the alignment trying to clear the jamb.
  • Anonymous Dec 23, 2008
    I had to return two of those printers to HP , im trying my third now, if i get paper jam problems, Ill request a refund.
  • Erich Powell
    Erich Powell Jan 07, 2009
    I have these Printers though out the Hospital here at work. Today two people called me with the same issue. The top feeder jams. As the IT Coordinator here I have had nothing but problems with these printers and I absolutely hate them. I have tried Cannons and Lexmarks as well. I am now at the conclusion that "all in ones" aren't such a good idea beings that if it isn't one thing, it's another.
  • rishulim Jan 30, 2009
    I hate this printer
    Jam paper message even if there is no paper inside!
  • Anonymous Feb 01, 2009
    half a sheet of paper is jammed - cannot get at it.
  • Anonymous Feb 03, 2009
    I have exactly the same problem.
    There is no paper jamming the thing.
    Any ideas?
  • Anonymous Feb 07, 2009
    I have the same problem. The paper fed in crooked and crumpled. In trying to remove the paper from the jam, a little piece of paper ripped off and stayed in the machine. Now I can't fax or feed paper from the top.
    This HP L7680 doesn't provide clear instructions for how to remove jammed paper. There should be a way to easily slide a stuck piece out, but instead it's a tough pull, a yank, and a rip. Where are the instructions from HP? m.
  • Anonymous Mar 02, 2009
    Same problem. No apparent way to get to the jammed paper top unjam it.
  • Anonymous Mar 31, 2009
    Same problem as everyone else!
  • Anonymous Apr 11, 2009
    I have the same problem with the paper feeder pulling the paper to the right, causing it to crumple and resulting in a jam. I have an HP laptop and it had probelms about 1 year into the lifespan and they took care of it, no problem. But with this printer, they want me to pay for an "upgrade" = refurbished printer. The irritant is, I really like the printer and all of the important functions work fine... just the stupid paper feeder causes a jam. You would think they would engineer a fix or provide a new paper feeder to keep customers happy.
I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
Posted on Apr 10, 2009
Though i have no paper jam, it keeps on prompting Clear paper jam then touch ok. Also notice the carriage not moving from right to left ,its making a weird noise.seem paper feeder gear stuck but clear
Hi vidya kowlessur,
I would be happy to help you with your Officejet 7500A printer. I understand you are seeing a message prompting you to clear a paper jam, and the carriage is likely jammed. Please use the following 2 documents to troubleshoot the issue;
HP Officejet 7500A E910a and E910c Wide Format All in One Printers Out of...
Carriage Jam or 0X610000F6 Message Displays for HP Officejet 7500A E910a...
I hope this helps, but if the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
Jul 09, 2015 | HP Officejet 7500A Wide Format...
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
I can't print anything as the paper feeds in crooked and jams
Perhaps there is still a bit of paper stuck in the machine from a previos jam? Follow the manual to clear a paper jam. Then "fan" your paper like a deck of cards before placing it in the feeder. Make sure the paper guide is not set too tightly causing the paper to not lay flat as it enters the printer.
Dec 05, 2009 | HP Office Equipment & Supplies
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Brother Intellifax 2800 Paper Jam Issues
Pull open the doc feeder and look for an obstruction. A wayward staple, paper clip, push-pin, post-it note?
Sep 27, 2008 | Brother IntelliFAX 2800 Laser Fax
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Hp officejet 7310
please check gear train and confirm no broken one-check of selonid not working in a right way and no foreign object droped inside(like pins).-check of smoth actuation of paper present detector.(in place and movement when you put papers
Mar 01, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Auto-Feeder Does not feed paper evenly
There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
3,942 people viewed this question
Seeker5211
Seeker5211
