Question about HP PSC 2410 All-In-One InkJet Printer
Copy settings When we make more than one copy the printer seems to scan just a little bit at a time and print really slowy. The next copies print exactly the same way. Its almost like we cant fast print after it scans even when we choose the settings. nancy
    Master:
  • 638 Answers
Its normal in hp printers.it is not a fault.still u can delete the old drivers and reload the printer drivers again.as it will delete all the old setting which is making it slow and will work properly.
Posted on Nov 14, 2008
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
I need to know the settings on the hp photosmart c7200 printer I should be set for me to get the absolute clearest scans of docs and also my drivers license
Hi. Here are the specs of your printer or simply follow this link to know more.. http://www.shopping.hp.com/shopping/data_sheet/cc567a.html
Print specifications -Up to 1200 x 1200 rendered dpi black when printing from a computer -Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200-input dpi -Print speeds vary according to the complexity of the document -Panorama-size printing -Method: drop-on-demand thermal inkjet -Language: PCL3 GUI -Duty cycle: Up to 3000 printed pages per month
Copy specifications -Copy resolution up to 4800 x 4800 -Digital image processing -Up to 99 copies from original (varies by model) -Zoom to 400%, fit to page (varies by model) -Copy speeds vary according to the complexity of the document.
Scan specifications -Image editor included -Integrated OCR software automatically converts scanned text to editable text (if installed) -Twain-compliant interface -Resolution: up to 4800 x 9600 dpi optical (varies by model); 19200 dpi enhanced (software) -Color: 48-bit color, 8-bit grayscale (256 levels of gray) -Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
May 06, 2011 | Office Equipment & Supplies
Can scan & copy, but can't print
It may not be the settings, it could be an outdated driver, if you are using the cd too install software, try downloading the software from hp website.
Feb 07, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
How do I get my printer to scan a photo to my computer? When I push scan it does nothing, if i push copy it will print a copy. Is there something I am doing wrong?
Yes you are. Try opening your printer's application on your computer and from there order your printer to make a scan. It will ask you where do you want to save it. I think. If not there must be a dialog windows where to input these settings. Next time you're asking something try to be more specific. For example what type of printer we're talking about.. :)
Nov 21, 2009 | Lexmark X3350 All-In-One InkJet Printer
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Apr 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Scaning
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print.
Make sure your computer is on. If it still doesn't copy, launch the Lexmark All-In-One Center software on the computer. You can do a copy from there... and it should put a little icon in your systray (lower right area of the screen)... that might re-enable the copy from the button.
Steve
Feb 22, 2009 | Lexmark X75 All-In-One InkJet Printer
KODAK ESP-3 AiO Will Not Scan On Vista 64 Bit Ulitmate
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
Feb 16, 2009 | Office Equipment & Supplies
HP PSC 2410 All-In-One InkJet Printer Logo
37 people viewed this question
Ben Johnson
