Question about Whirlpool LER4634J Electric Dryer
How to remove the back
I have the same problem with Whirlpool Dryer Model YGEW9868KQ0. Tried to removw the back, took off the screws but it appears to be welded top and bottom?? 2screws hold the top in place but the rest do not grip anything ??
  • Jcharlto Oct 28, 2008
    Interesting. I have 6 hex head screws. They were removed from the back, two at the top in line with the two that hold the top in place, and two from each side. When I examined the inside there is nothing to be re-attached. Nothing on the floor and nothing dangling anywhere. Any idea what I might be missing. Forget how I got into this thread, but the model # is YGEW9868KQ0
  • 550 Answers
Dryer back does not come off, the screws removed secure parts to the inside of the case.
put them back before anything detaches.
the front panel comes off
  • pull wall plug
  • remove lint screen
  • remove 2 screws in housing under lint screen
  • with putty knife or other blunt blade in gap between top and front,
    depress spring catches at both corners of top panel front, tilt up top
  • remove 1screw each side 1/3 down front panel
  • remove door swicth wires
  • tilt front panel down and remove
all internal parts are accessible
perform repair
examine rear of case from inside and refit anything detached by screw removal
reassemble in reverse order
Posted on Oct 27, 2008
I dented the top of my dryer (Whirlpool Cabrio model number WGD5600XW0) and want to know how to remove top to fix dent.
-Here a sample to remove most brand 's top.
-Unplug the power, then remove couple screw on the upper back
-Now use Flat head screw driver wrap the tip with clothe then pry the front that sit on the end up.
Good Luck
Mai
Nov 14, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
HOW TO GET INTO THE CABINET OF MODEL LER3622HQ0 WHIRLPOOL DRYER
You will need to remove the top panel, then the front panel in order to access the dryer interior on this model. With the dryer UNPLUGGED, follow these steps:
1. Locate the screws for the top panel in the REAR of the dryer. With the screws removed, the top panel should slide back, then lift off so you can access the screws holding the front panel in place.
2. Disconnect the door switch connector and any ground wires that may be attached to the front panel. Then, remove the panel screw on each side that holds the front in place. With the screws removed, the panel will lift up, then come off.
You should now have full access to your dryer interior. If you have any questions about this procedure, or if you need additional advice, please post back and let me know. I hope this helps you.
NOTE: There are helpful exploded view parts diagrams that can assist with disassembling and reassembling your dryer at the following websites:
searspartsdirect.com pcappliancerepair.com appliancepartspros.com
Aug 15, 2010 | Whirlpool Dryers
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
Maytag Dryer model # LDE313
at the bottom of the front panel you have two screws, remove those and swing out at bottom and drop off
Feb 06, 2009 | Whirlpool GEW9250 Electric Dryer
Can't remove motor from Whirlpool dryer (LER3624EQ1)
no set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer
From the sound of your problem, it appears you may have a faulty overtemp switch that gets too hot , opens the circuit to disable gas and flame, then cools down and allows it to start again.. Since you didn't provide a specific model number with your question.. use this link to find replacement whirlpool thermal fuses etc.. http://www.pcappliancerepair.com/whirlpool-dryer.php#fuse
Hope this helps..
Sep 06, 2008 | Whirlpool Dryers
Whirlpool gas dryer model # lgr7646eq3
put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Sep 03, 2008 | Whirlpool LGR3624JQ Gas Dryer
Removing top from Whirlpool Gold Ultimate Care Model GEQ8858KQ0 Dryer
Here is the answer to my own question and for anyone else who may have a similar noise problem with coins , metal objects, etc getting under the vanes or fins in the dryer drum. DISCONNECT OR UNPLUG DRYER-Remove 4 screws from the back edge of the control panel on the back of the dryer. Then lift up on the backside of the cover that also has the control unit attached to it. Slide the top cover towards the front of the dryer and then lift up on front and lay the entire cover and control panel towards the back of the dryer. A wall works great to hold this out of your way. The control panel remains on the cover and the drum will stay intact. Rotate the drum to locate which fin or vane the object is located. Move this vane to top and then remove three screws that is holding the vane. These are course threaded screws that screw into the plastic vanes. a nu6t driver was required. After removing the vane I found a quarter, and a few lint balls, There are only three vanes in the drum, so take about 10 more minutes and remove all three vanes to clean out the lint.To reinstall cover slide the cover back onto the two clips(one on each side) push towards back, checking to make sure front is held down by the clips, then replace the 4 screws on backside of dryer. If the lady of the house is around, it would now be a good time to clean out from behind and under the dryer to get up the rest of the dust, lint, and whatever remains or was lost.
Sep 01, 2008 | Dryers
Whirlpool dryer
reinstall back.. remove 2 screws under lint screen press 2 clips on front corners with putty knife lift top remove screw on each side top inside front lift front off belt goes over drum ..double it and pass through idler support arm then onto motor pulley ..belt pack may have a diagram
Jul 31, 2008 | Whirlpool Dryers
Whirlpool LER4634J Electric Dryer Logo
433 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
