Question about Shuttle XPC SN41G2 (XPC-SN41G2-SHUT) PC Desktop
Takes up to 30 mins to turn it self on
My shuttle computer it taking longer and longer to show any sign of activity when I press the power on button. It can take nything form 5 mins to 30 mins to switch on. When it comes on it operates normally. Prior to that there is no sign of activity and no extenal lights on. What could this be due to?
  • shuttleKid Nov 24, 2008
    I have the same problem. Eventually, it wouldn't power up at all.
    Any suggestion. Problem supply failure or motherboard problem ?
    Is this worth to repair ?
Contact with Shuttle confirmed that the power supply was the problem. Replaced the power supply and problem solved
Posted on Dec 08, 2008
I had the same problem with 2 of these systems.
You need to replace the power supply.
I know it's a weird problem. It seems like it shouldn't start at all.
But it solved the problem with both of the systems.
here is a link for the power supply at a few stores:
Hope this helps.
Manual www princetongraphics
try taking the batteries out or go to the shop where you bought it and go from there...good luck lol :-P
Oct 10, 2013 | Princeton Digital VL1919 19" Monitor
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
Wont stay on. It'll load for 3 secs then turn off
The Calculator has a feature that takes it into standby after a certain delay of inactivity. Possible values of the delay are 1 min, 3 min, 5 min, 10 min, and 30 min.
In view of this, your 3 sec value seems too short. I suspect that the batteries are depleted.
In OS 2.x, press 5: Settings & status, then 3:Handheld Setup. Look for drop down box to the right of Power Standby, and select a longer delay.
Feb 04, 2011 | Texas Instruments TI-Nspire Graphic...
My Officejet 4315 All-in-One is printing very very slow How do I fix this problem? I have restarted it and unplugged then replugged it and have restarted the computer and it still prints really really...
The very first thing you need to do determine whether the issue is in the Hardware or in the Software for that on the printer .
1. Load plain paper in the tray.
2. Press the Setup button
3. Press 2 to select Print Report
4. Press 4 to select Self-Test Report . The self-test page prints.
Measure the time (in seconds) it takes for the test page to prints.If the test page prints in less than 60 seconds , this is normal print speed and you do not need to troubleshoot.If the test page prints in more than 60 seconds , go to the next step.
Important ;
Some products print faster than others. If the test page exceeds 60 seconds, and other documents you print typically take as long, the print speed is normal. Troubleshoot this issue only if your product is designed to print faster than about 60 seconds a page or if printing is slower than usual.
Check the power supply. to check the power supply you need to follow these steps.
1. Turn the product so that you can access the rear side.
2. Unplug the power cord from the back of the product.
3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
4. Plug the power cord directly into a wall outlet.
5. Print and time a self-test again.
If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet. If the test page takes significantly longer than 30 seconds to print, continue to the next solution.
Incompatible cartridges can cause the slow printing problem.
Which cartridges you use depends on your country or region. To check the cartridge compatibility you can go to this site (for hp printers) and check The number on the cartridge label must match the numbers listed on HP SureSupply.
1. Press the Power button and turn off the printer.
2. unplug the power cord. Disconnect the data cable(USB,Ethernet depending upon the the product set up). wait for 30 secs. reconnect all the cable and than try to print a test page.
if these steps resolves the issue than you dont need to continue troubleshooting or if the issue persist than Replace the Power supply for your product.
Jul 06, 2010 | HP Officejet 4315 All-in-One Printer
Describe how to use the self timer on the samsung S830 digital camera
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
Jan 11, 2010 | Samsung S830 Digital Camera
It takes 30 minutes to print a page
Press and release OK and CANCEL buttons on the unit and release. This will print a self test report. Check the timing. It should not take more than a minute to print a self test page. If it does, please let me know.
Jul 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Canon 10D takes 30 seconds to shoot after sutter button depressed
You may have it set on shutter priority or the like with the time set to 30 seconds. Try set it to landscape, portrait etc, one of the auto modes, and it should clear up the problem.
Feb 17, 2009 | Canon EOS-10D Digital Camera
Masterplug 4 in 1 remote control
There is no bush listing in the manual
You can perform a manual search.
Press and hold TV,SAT,DVD or VCR until the centre light blinks red.
While it is blinking press 0000
The flashing will speed up.
Press the power button repeatedly - it will cycle through all codes.
When your device turns off (powers off) press the okay button.
It should now power on and off correctly.
Check the other buttons to see if everything works.
If it does not start the process again - it will hit another code which will also power down the device - takes a long time but should work - manual states it may take 20 mins - practise says longer
Jan 19, 2009 | Philips Magnavox Learning Universal Remote
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Shuttle XPC SN41G2 (XPC-SN41G2-SHUT) PC Desktop Logo
233 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
