Question about HP PhotoSmart M627 Digital Camera
HP Photosmart M627 Digital Camera
When I connect the camera to my computer, my computer says that there is no pictures on it even though I have taken photo and can see them on the camera. I have install the software and done everything I can think of to try and fix the problem.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Sep 14, 2012
PCTServices
  • 120 Answers
SOURCE: software
here are the drivers. You can use any photo software with this camera http://www.camera-drivers.com/drivers/120/120688.htm
Posted on Sep 30, 2007
SOURCE: camara hp m627
la camara cuando enciende dice error lens: m627-30 que significa eso y como puedo repararla
Posted on Jul 31, 2008
SOURCE: hp photosmart m627
We had the same issue - audio but no video on playback on a Win XP pc on both Windows Media Player and Media Player Classic. At some stage it suddenly stopped working - I suspect a Windows update?
I've found video plays back correctly with the VLC player: http://www.videolan.org/vlc/
I've raised a support call with HP regarding this issue.
Posted on Mar 31, 2009
  • 1162 Answers
SOURCE: my camera has error 31
Your problems most likely came from it being dropped. The fix is time consuming but well worth it since this camera is a nice one to use. You are going to need a set of small screw drivers philips and straight. Also a soldering iron. Take the back off. Easy enough. Then remove the obvious screws you can see. Heat the iron up and remove the solder joints at the battery compartment. there are two and if you have taken all the screws out it will fall into your hand. Dont forget to remove the screws on the top board as well. If you turn the barrell on the lens you might hear a snap and that is a sign the lens has fallen back on to the track. If not take the screws out of the gear box and set the track on the barrell of the lens. This is not all that hard I have done several. Different cameras use different ways of getting to the motor drive. Most you dont have to unsolder, but with this one you do. I love this camera and it is worth the effort to fix. Write if you have problems
Posted on Aug 04, 2009
  • 102366 Answers
SOURCE: I have a hp photosmart
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
How do I add my hp photosmart m627 to computer devices and printer list?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Sep 27, 2014 | HP PhotoSmart M627 Digital Camera
Hi I have just bought an HP Photosmart M627. It seems to switch itself off without any warning if I don't take a picture straight away. The on/off button remains lit though, so is this power saving or do I...
This sounds like power saving...some cameras allow you to set the time for power down. Go into the menu and see if you can find anything that would permit you to do that.
Dec 15, 2009 | HP PhotoSmart M627 Digital Camera
Will not take pictures AT ALL all of a sudden
What does the display say on the back? error 31 or something like that?
May 27, 2009 | HP PhotoSmart M627 Digital Camera
I have a hp photosmart M627 camera. When I turn it on, the lens stays in and comes up on screen with a lens error:M627-31. Can you help please.
Jan 18, 2009 | HP PhotoSmart M627 Digital Camera
My camera will not take pictures
It cant be fixed
It is a firmware failure.
Replace the camera
Dec 18, 2008 | HP PhotoSmart M627 Digital Camera
Lens error M627-31
Took camera to my local camera shop for advice and repair very fast response from them
Oct 14, 2008 | HP PhotoSmart M627 Digital Camera
Camera hp m627
This is probably THE most common failure among digital cameras.
Jul 09, 2008 | HP PhotoSmart M627 Digital Camera
Camara hp m627
Open Questions:
See all HP PhotoSmart M627 Digital Camera Questions
HP PhotoSmart M627 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
