Question about Lexmark C534N Printer
Printer leaves light red marks on area of page not printed on
When printing, the area of the page not printed on has a light shading of red ink
  • 300 Answers
This is normally caused by the PC unit (photo conductor unit) you will see four of them sitting on the inside of the front cover if you open it. To check if this is the problem you can swap these around, so swap the magenta with another colour, then print something, if the problem have change to the other colour you will know this is the cause and the unit will need replacing.
Hope this helps
Posted on Apr 19, 2009
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
How to refill hp deskjet 1560 black cartidge
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Yellow not printing properly.
Go to the maintenance section of your printer on your desktop and clean the cartridges
Start - printers or Start - control panel - printers
Also check the level of your ink while you're there
May 08, 2010 | HP Deskjet D2360 InkJet Printer
Won't print words!
sounds like a couple of things....
the document program your using, when printing, check to see what is printing (pages) you can select one, current page or multiple. also check the attributes for printing.
check the settings for the printer, you might be out of ink
lastly, in the document, go to the Page File and scroll down to see if the shaded areas need to be 'set to back'
hope this helps and good luck
Apr 29, 2010 | Brother MFC 490cw Color Inkjet...
Dell 3110cn Printer prints shades of pink
Have you pulled out the imaging drum and transfer roller to see if they are caked in Magenta toner? if so they will need to be cleaned off. Would also suggest blowing out the area around the drum to rid of loose toner in that area.
Feb 15, 2010 | Dell 3110cn Laser Printer
Ink marks on paper
seems that the Print roller needs a cleaning. get it cleaned as there might be some extra ink on the roller.
Hope this Help.
Jul 16, 2009 | Lexmark E330 Laser Printer
Ink low indication on HP Deskjet F4288
hi im josh in cebu phils.may i help you? Friend the problem is the ink level dropped 3/4 after printing 7 pages and low exclamation mark in red. Friend it is the real deal since you are using a free ink cartrdge with your printer that ink is only a sample one and the content of that cartridge is not full thats why it dropped to empty in just a few pages of printing. It just appear full in the ink level monitoring since the printer auto detects new cartridge on the tank. It is just so You need to buy a new ink cartridge the one with the full content.and i'm sure it will last a long time since it is already full. thats all friend good luck hope i helped you.
Mar 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
Different looking text, but only in certain areas of the page.
Samsung CLP-300 color laser leaves 3-4 lines of various shades of black in middle of paper. Otherwise everything is great.
Posssible black toner cartridge problem?
Jan 30, 2008 | Samsung CLP 300 Laser Printer
Lexmark C534N Printer Logo
189 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
