Question about Vizio L32 32 in. LCD HDTV
Picture is cut off at top and bottom
My picture is not completely visable. The top of the screen cuts off some of the picture.. I cannot view captions on the bottom of any screen. I have tried the "zoom" button. I have tried another "view" button, but none give me the complete picture that should be there.
Thanks.
  • Mark Yount
    Mark Yount Oct 23, 2008
    I have the same problem, and I didn't used to have it.  Just happend in the last couple of weeks.
  • Anonymous Apr 20, 2009
    same problem
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Posted on Mar 13, 2009
  • 3 Answers
Have you tryed pushing the wide button? This button changes the screen to a panoramic or normal view. I usually have mine set on the panoramic view and nothing gets cut off and it is still a full screen unless you have a movie in that may stretch the picture more and even on the normal mode the top and bottom will be cut off.
Hope this works for you!
Posted on Nov 12, 2008
Resizing picture on vizio e43-d2. the picture is cut off how do I resize it
You can use zoom but that will reduce the clarity of the image and you will loose some of the view. The "cut off" as you say is due to the aspect ratio of the video you are watching, that is to say width to height, when the picture has blanked out top and bottom sections it is because it is shot in wide screen format.
Apr 05, 2017 | Vizio Computers & Internet
Tv is not showing complete picture....some things are cut off
Change the aspect ratio.this can usually be done via the remote or through the tv menu.normal view for most wide screens is wide 16:9 but if you have zoom or crop black bars then you may lose parts of playback.
Feb 19, 2015 | Vizio L37 Television
UN46EH5300 adjust screen size to get whole picture and closed captions
Sounds like you have it on zoom setting. Go to the picture menu and scroll through the options. Start with 16:9 and try others if this doesn't work. If you've already tried this, you may have to go into screen setting and manually draw the picture in horizontally and vertically - but make sure you've got it on 16:9 and paused on a typical picture before you mess around with these settings.
Aug 22, 2014 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
The top of my picture is cut off.
Change the video output to wide screen
Oct 15, 2009 | Sony Televison & Video
Cuts off the bottom of my pictures
that happens to my camera also
what i think is happening is that live view uses a digital immage not what the image sensor sees when you take the picture the optical view finder uses the atual immage that the sensor will see
May 25, 2009 | Sony Alpha DSLR-A300 Digital Camera
My closed captioning is getting cut off
Are you changing the format or picture size. Some times marked zoom on the remote. Are you using a cable box or SAT recever. These boxes also have setting for format change.
Apr 24, 2009 | Televison & Video
Images displaced, cut off at bottom & extra content at top.
flash trans. is broken i want to replace if there any matching ?
Dec 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
JVC av-56pw30 Picture Adjustment
Sounds like you have a convergence problem and the set will require repair. This repair will run somewhere around $400 if you have a good company complete the repair for you.
If you are interested in doing this repair yourself you will need to be able to use a meter and solder VERY well.
If you have more questions please email me.
Thank you,
Tim Nolan
Experttv@comcast.net
Oct 11, 2008 | Televison & Video
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Big black box at top of screen
If you mean that a black box appears on the screen, and you can still see the picture around the box, it means that your closed captions are on and set to TEXT. If this is the case, enter the menu, navigate to the closed captions page and set the captions to OFF. If you mean that the top of the picture has collapsed down, the vertical circuit has stopped working correctly and the set should be serviced by a qualified tech.
Sep 15, 2007 | Philips Magnavox 27MS343S 27" TV
Vizio L32 32 in. LCD HDTV Logo
3,786 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
