I just bought a use Monitor 2400,it will run and then start to beep,has E 14 on it, What does that mean? Don't have the manual for it.
SOURCE: we have a monitor 2400
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
[email protected]
SOURCE: Monitor 2400 Kerosene heater service
Drain the air out of the supply line at the bulk tank shutoff valve; there should be a small hex plug for doing this. On the bottom right hand side of the heater is a round hole that allows access to a finger pump for the fuel; press this three times slowly. Heater should start!
SOURCE: looking for repair of monitor 441 kerosene heater
Did you get your Monitor repaired? I'm located just north of Winston Salem. You can email me at [email protected]
