Question about Canon PIXMA iP90 Mobile Printer
CanonPIXMA iP90 Color Ink Tank installation problem
I keep getting an error message that reads: "The following ink tank is not installed: Color Ink Tank. Install the ink tank properly and close the printer's cover. If you do not want to install the ink tank, click cancel."
The cartridge is installed properly. While traveling, I removed the ink cartridges for 3 weeks. Once I settled in Mexico, I tried to use the printer and kept getting the error message. I tried cleaning, deep cleaning, print head alignment, and installing new cartridges. I occasionally am able to print a test page, but the ink pattern is not good, even with a new cartridge. I have the exact same problem as posted by Javid on Sept 9 2008
Do you have any solution?
  • 76 Answers
Yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Posted on Oct 24, 2008
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
Showing Check Ink U051 COL. Have removed the
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon PIXMA MX310 All-In-One Printer
U150--cartridge is not reognized
If the following error occurs "The following ink tank cannot be recognized" error code U043, U140, U150
Action 1 : The ink tank is not installed in the ink tank. Install the ink tank. Refer to "Replacing an ink Tank" below.
Action 2 : The ink tank is not compatible with the machine. (The lamp on the ink tank is off.) Install an appropriate ink tank.
Refer to "Replacing an ink tank" below.
Replacing Ink Tanks.
Action 3 : An ink tank error has occurred (The lamp on the ink tank is off).
Replacing an ink tank :
Replace the ink tank using the following steps :
1) Open the Paper Output Tray.
Put your finger in the rounded indent of the Paper Output tray and open it gently.
2) Make sure that the machine is turned on, and lift the Scanning Unit (Printer Cover) until it stops.
The Print Head Holder moves to the center.
Caution : * Do not hold the LCD or the Operation Panel.
* Do not hold the Print Head Holder to stop or move it.
Important : If the Scanning Unit (Printer Cover) is left open for more than 10 minutes, the Printer Head Holder moves to the right side. Close and reopen the Scanning Unit (Printer Cover) to return the holder to the center.
3) OPen the Inner Cover.
Caution : Do not touch the metallic parts inside the machine.
4) Remove the ink tank whose lamp is flashing fast.
Push the tab and remove the ink tank.
Important : * Handle ink tanks carefully to avoid staining clothing or surrounding area.
* Discard empty ink tanks according to the local laws and regualtions regarding disposal of consumables.
Note : * Do not remove more than one ink tank at a time. Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare the replacement tank.
a) Remove the new ink tank from its packaging.
b) Pull the orange tape to peel off the protective film.
c) Remove the film completely.
Important : Make sure that the protective film does not remain in the air hole. If the air hole is blocked with the remaining film, ink may leak out or may not eject properly.
d) Remove the orange protective cap from the bottom of the ink tank.
Discard the cap once it is removed.
Important : * Do not touch the electrical contacts on the ink tank. Doing so can cause the machine to malfunction or become unable to print.
* Be sure to remove the clear film from the ink tank in the exact order, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
* Do not squeeze the side of the ink tanks as this may cause the ink to leak out and stain your clothes and hands.
* Do not reattach the protective cap once you have removed it, Discard it according to the local laws and regulations regarding the disposal of consumables.
* Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
6) Install the ink tank.
a) Insert the front end of the ink tank into the Print Head. Make sure the position of the tank matched the label.
b) Press on the "press" mark on the ink tank until the ink tank snaps firmly into place.
c) Make sure that the ink lamp lights up red.
Important : Install all the ink tanks to print. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note : Make sure that the Inner Cover is closed. Printing will not start with the Inner Cover open since paper cannot be fed properly.
8) Gently close the Scanning Unit (Printer Cover).
Caution : * Be sure to hold the Scanning Unit (Printer Cover) firmly using both hands, and be careful not to get your fingers caught.
* Do not hold the LCD or the OPeration Panel.
Note : * When you start printing after replacing the ink tank. Print Head Cleaning is performed automatically. Do not start another operation until the machine has stopped making operating noises.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Color tank isn't installed --- but it is!
Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
Nov 07, 2009 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Inaccurate error message
According to Canon's website:
Details Print Friendly Version Issue: ERROR LCD: More than one ink tank of the following color is installed U071
Solution: Replace defective ink tank (MP500 / MP800)
Replacing An Ink Tank Use the following procedure to replace empty ink tanks or when an ink tank error appears.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.).
  4. Press the ink tank's tab (1), then remove it from the slot (2).
  5. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
Aug 14, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA iP90 Mobile Printer Logo
514 people viewed this question
old marine
old marine
