Question about Cameras
Lens won't retract and camera won't start even with new batteries
The camera suddenly stopped working where there seems to be no connection to the battery. The lens opened and I can't get it to retract. I purchased new batteries and that did not work. My product is not canon or konawag. It is Samsung Modle 630.
    Guru:
  • 1,894 Answers
No. the lens are stuck.. give a smal force to push the lens... if not use a small pin
Posted on Oct 20, 2008
    Genius:
  • 1,550 Answers
There will be some bit of paper or dust blocking the movement of sensor .
You need to blow air to remove the dust .
It will work .
Sony cybershot dsc w80 wont turn on or retract lens. My camera suddenly stopped working one day, do not recall dropping it, etc. My mother has the same camera and I tried her battery and it still doesnt...
From your description, I would say something is stuck inside the lens mechanism of your camera. It could be a grain of sand or any small particle like a piece of fabric from a camera bag.
Hold you camera lens facing the ground and gently - moderately tap it repeatedly. You can also try spraying a compressed air into it.
Thanks for using Fixya!
Oct 26, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
Camera stoped working and lens is in the out position, i can't get it on again
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Feb 28, 2010 | Samsung Digimax S750 Digital Camera
Lens is stuck about 97% open. The camera will not
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 04, 2009 | Canon PowerShot A520 Digital Camera
Sony cybershot DSC-W170 lens malfunction
sounds like you have dust, sand of some type stuck in the retracting lense. Ive found someone to tell me to take out my batterys and SD card, then tap the bottom of the camera on a table top. Replace the batteries and power up. Doing this, I was told it loosens up the debri for the lense to retract to close and to open again.
Aug 24, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Canon A560 dropped.when the cam is on lens wont retract anymore
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens will not retract
Lens errors (E18 errors on some Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Feb 07, 2009 | Canon PowerShot S1 IS Digital Camera
Hi
Either the fuse has blown or there is another problem with the main PCB or possibly the battery door indicator switch.
Open the battery door, by the memory card slot is a tiny switch; is the black tab for the switch still there or is it broken off and missing? Is it jammed down? Try holding the switch down with a pencil and press the power button... does it work?
If it doesnt seem to be the switch, it's probably the fuse. If you can solder well you can probably replace it yourself, and I will get the fuses tracked down and listed in the store so they are available to anyone who needs them.. they are cheap!
We are a digital camera repair business, if we can help please let us know! Good luck from Darntoothysam com
Thomas
Darntoothysam com
Oct 20, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Screen goes black and camera shuts off
Are you using lithium batteries?
All Kodak cameras seem to have issues with alkaline batteries.
Although lithiums cost more, they work well and provide better value and performance than alkaline batteries.
Mar 17, 2008 | Kodak EasyShare C613 Digital Camera
I had exactly the same problem and I went to this site and got my solution. I banged the bottom of the camera with my palm and turned it off and on at the same time. On about the fourth bang the lens retracted and cleared the error codes. I know, "Caveman Maintenence" but it worked. Can't hurt to try...
Dec 10, 2006 | Kodak EasyShare CD33 Digital Camera
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
