Question about Frigidaire Dishwashers
I have a Frigidaire Ultra Quiet Plus dishwasher. The top spray arm isn't spinning during wash. The bottom spins fine and I can spin the top freely by hand. It appears there is not enough water pressure gettig to the top spray arm. Any suggestions? Tanks, Sam
I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
www.frigidaire.com/support/FAQ-Dishwasher.asp#6
Posted on Dec 14, 2008
Frigidare ultra quiet 1 top wash arm not cleaning properly
Hello ezideas - First I suggest verifying that there is enough water pressure coming into the unit and that it is at least 120F. Do you noticed if the spray arm will rotate freely or if it is damaged? If so, the spray arm assembly may need to be replaced. Connect with a professional to accurately pinpoint any potentially more serious issue.
Jan 14, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Top spray arm does not turn during wash or turns slightly..it is free of clogs and spins freely by hand
It will spin freely by hand, but needs to spray water out of the jets at the trailing edge of the arm. Check inside the arm for blockage and make sure that water is getting to the upper arm from the pump.
Feb 13, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
The upper arm is free spinning by hand, but from all indications, it is not spinning. Water is flowing freely and drain is excellent. Is the upper arm problem a major repair.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 01, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
My frigidaire ultra quiet spray arm doe's not move.Water trickles out the holes,no pressure.
water does not spray on the top arm until a later cycle...only one arm spins at a time... a fridgidare thing
May 11, 2010 | Frigidaire 24 in. FDB126RB Built-in...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Top rack not cleaning
Some dishwashers have a telescoping nozzle in the center on the bottom. If this is blocked by a large pot in the middle of the bottom tray, the nozzle will only extend up into the pot, and not be able to spray the entire top rack.
Also, some models have an arm mounted in the top. Check and see if it can spin freely, and if it's nozzles are clogged.
De-clog by soaking the part in vinegar.
Sep 17, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwasher
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Open Questions:
Dishwashers Logo
689 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
