Protron PD-800 DVD Player
Problem for Protron PD-800 DVD Player
HELP WITH DVD PLAYER
By CHERYL on Jul 01, 2006
BEEN HAVING PROBLEMS WITH MY DVD PLAYER VERY FEW MOVIES WILL WORK ALL OTHERS SAY WRONG DISK CAN ANYONE TELL WHAT I NEED TO DO OR WHAT IS WRONG WITH IT THANKS CHERYL
Same Problem
Dec 26, 2007
-   i have 2 pd-2302 dvd players and they both have the same problem. they wil play the movie and then they will start sticking and the sound messes up. i put them on another dvd player and they work. i tried using a lens cleaner on one but still have the same problem. is it fixable or should i just thrash them. thank you-   elcab1241
Dec 09, 2007
-   DVD PLAYER SAYS WROND DISK HOW TO CLEAN LENS WITHOUT DISK CLEANER-   Guest
Nov 09, 2007
-   My players Protron PD-800 will only play very few DVD's comes up and says wrong disk-   Gamm
Solution #1
posted on Jan 27, 2008
Somewhat Helpful)
sherizzle
Rank: Apprentice
Rating: 78%, 4 votes
yes you can take out disk, then click setup on remote, then hit + and - over and over until you see the code pop up on the screen. Arrow over to change code. I have the same problem but don't know which code to put it on. 255 is not working for me.
Was this helpful?
Yes
No
Solution #2
posted on Jul 01, 2006
Somewhat Helpful)
techman
Rank: Guru
Rating: 86%, 7626 votes
Have you tryed cleaning the player yet with a disc cleaner or by opening the unit and cleaning off the lens very carefully with a cue tip? try that first . Good Luck
Was this helpful?
Yes
No
Solution #3
posted on Jan 22, 2008
Somewhat Helpful)
cheapz
Rank: Guide
Rating: 85%, 11 votes
This is often a problem with the DVD player software thinking it is in a region different than your discs. (DVD discs are often encoded with 'region codes' meaning a disc purchased in Asia will not work in a player expecting to see North American discs)
What can happen is the player 'forgets' where it is, and your regioned discs won't play any longer (region free discs should continue to work as will audio CDs ....)
A power surge, random cosmic ray or similar flakiness can cause a player to 'forget' what region it was designed for ....
If that is what has happened you need to 'reset' the region code.
Altho I can diagnose this, I have NO CLUE as to how to do this with a Protron PD-800 DVD player. Anyone out there know how to reset the region codes for this (or generically for a DVD player?)
Thanks!! //cheapz
Comments:
Mar 23, 2008
- 'setup' on this remote does NOT get you to a service menu .... is there something I'm missing? Yes, there is no disc in the machine, and the only buttons marked + and - are the volume controls, and they do nothing in the setup menus ....
Was this helpful?
Yes
No
Solution #4
posted on Jun 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I CAN NOT TURN ON MY AUDIOVOX DS102 AT ALL
Popular Solutions for Protron PD-800 DVD Player
Questions and Unsolved Problems for Protron PD-800 DVD Player
Do you recommend Protron PD-800 DVD Player?
Answer
Answer
Have no sound or picture, sounds like DVD is running. Tried on multiple TVs with RCA cord and... (More)
Answer
I have a Magnavox Universal Remote and I have no code to program into the remote for it to work the... (More)
Answer
I have a Protron DVD player that the remote broke on. I can't find the remote code anywhere to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Protron PD-800 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
