Question about Sharp AR-M160 Laser Printer
Sharp ARM-160 When feeding though the feeder it works but the second we open the top it gets paper jam in the feeder area. No jam in the feeder area. Turn of and on and use on the glass no jam?? Help? Any Ideas
    Problem Solver:
  • 7 Answers
Check the paper path.you should see black little trip levers,they work as paper sensors.if foreign object gets into those sensors,you will encounter that type of error.also,if the sensors are faulty,you get the same error.
Posted on Jun 10, 2009
Paper wont feed
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X5650 AllInOne InkJet Printer
Why does paper go in crooked and then jams
Mar 09, 2012 | Lexmark X2500 All-In-One Printer
Lexmark X2650 printer--How to remove a paper jam when you cannot see the paper
Feb 24, 2012 | Lexmark X2650 All-In-One InkJet Printer
Says paper jam and there is no paper jam
Feb 19, 2012 | Lexmark X2600 InkJet Printer
Paper gets stuck pulls downone side only
Leading cause of paper jams and misfeeding is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
Jan 29, 2012 | Lexmark X5650 All-in-One InkJet Printer
Paper wont feed
Jan 09, 2012 | Lexmark X Office Equipment & Supplies
Lexmark printer wont print
Jan 04, 2012 | Lexmark X4650 All-In-One InkJet Printer
New printer not feeding
Jan 01, 2012 | Lexmark Office Equipment & Supplies
I have a 6600 printer I am getting a paper jam though this no paper jam.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 29, 2011 | Lexmark C533DN InkJet Printer
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Sharp AR-M160 Laser Printer Logo
196 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
