Question about NEC PlasmaSync 50MP2 50 in. Television
Picture when tv gets hot picture goes out. Is there a safety cutout for overheating?
  • covenant_692 Jan 27, 2009
    Same problem. I thought it was due to overheating too. Turn off TV and back on again then it works for another 10-15 minutes then goes out again (assuming again from overheating). When first turned on, it goes for as long as two or three hours, but then cuts out and gets gradually worse (faster) cutting out each time.
    Would love to know how to solve this one.
    Problem Solver:
  • 6 Answers
There is a small fan in every tv (like a computer) that cools the circuitboard in your tv. if your tv is dusty around the vented areas then air might not be getting in it to allow it to cool. if this fan is not working then your circuit board is not getting cooled at all and just will continue to over heat until it shuts off. at some point it will shutoff for good. so if it is a heat issue getit looked at by a tv repair shop. its a simple and cheap fix. but it could also just be a loose fuse in ur tv that pops out due to shaking around the house or high volume. in this case depending on wat kind of tv you have you can fix it urself or take it to a tv repair shop or send it back to the manufacturer(hopefully you sent in the warranty).
Posted on Feb 21, 2009
Gateway ZX 4800 has green haze over the screen sometimes it goes now its still there
make this test and fix it. God bless you
Overheating
Temperature is a common reason why many Rear-projection TVs do not perform well when they get to hot. You may start to see your TV shutting down automatically when it overheats. Here are a couple of things you can do to prevent overheating. First make certain any TV ventilation ports are free and clear of debris and dust. Second make sure the TV has enough room for airflow. Third, the temperature in the room should be around 72 degrees. Due to the high degree of heat generated by a rear-projection TVs, it is not advisable to watch TV on a hot days when you don't run the air condition. This could cause damage to your TV.
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Televison & Video
My soney projection tv turnes on and makes a sizzly sound for about 5 minutes and then the picture goes out but i still have sound.
You have a fault in the High Tension side of the TV set. This fault is causing the Tube Safety cutout is "Tripping" probably due to over voltage.
Feb 09, 2010 | Televison & Video
Picture goes away on my DLP TV
that is an overheating problem. With the TV unpluged clean and or vacuum the internal tubes. Not the lamp though. Do not touch the lamp as any oils on your hands will cause a hot spot and the expensive lamp will fail.
Dec 08, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Picture goes black mins after watching
Bad flyback transformer. It has a short in the winding making the Horizontal output transistor heat up so when its too hot the set goes into protection.
Aug 25, 2009 | RCA D52W23 52" HDTV CRT TV
Tv goes to straight line in center of picture then
It happens when Vertical deflection stops as Vertical Out IC becomes hot or does not get vertical signal.
Please check electrolytic capacitors and dry solder joints in vertical out section in TV.
Aug 12, 2009 | Sanyo Televison & Video
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV picture goes out
The tv is shutting down because of a power problem. It could be the power transformer or a color gun overheating. Expect at least a couple of hundred dollars to fix it. Some shops will do house calls for around $65 and can diagnose the problem and give you an estimate. Usually they can just remove the board, take it to the shop and repair it, then reinstall it.
Nov 03, 2007 | Televison & Video
NEC PlasmaSync 50MP2 50 in. Television Logo
118 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
