Question about Singer CSP1 Iron
Singer iron my singer iron stop working all toghter
  • Singer Master
  • 43,501 Answers
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Aug 22, 2010
What could cause the singer 9960 presser foot does not lift with presser footlifter
Apparently the lifter is loose or broken. Remove front cover , check movement of lifter where lifter stops movement will be where your problem begins!
May 28, 2014 | Singer 9960 - 9960 Quantum Stylist
Singer magic steam press 7
singer magic 7 is used carefully as it is closely to iron so check if wires are connected correctly
Jan 22, 2014 | Singer Electronic Steam Press Iron
My Singer sewing machine model #7470 keeps stitching after I remove my foot from the pedal.
Mine was doing the same thing. I called Singer and if the reverse stitch is working fine, it's a problem with the foot pedal. They sent me a new one under warranty. If the reverse stitch is having issues as well, then it could be a problem in the machine itself.
Feb 02, 2013 | Singer 7470 Confidence Sewing Machine
Reset singer iron
1) test the power cord
2) no power to receptacle
3)open thermostat
4) open the heating element
5) defective main switch.
6) if you iron has electronic control the board can be faulty.
see the diagram
God bless you
Sep 09, 2012 | Singer ESP2SB Iron with Auto Shutoff
Instruction manualfor csp-1 singer
Located here
http://www.amazon.com/Singer-CSP1-Magic-Steam-Press/dp/B00006IV4K
Jun 25, 2010 | Singer CSP1 Iron
Lost intruction manual Magic Steam Press csp-1
Follow the link or copy it to your browser - http://www.singerco.com/accessories/manuals.html - and search for your Singer.
Kind regards Ryno
Jun 20, 2009 | Singer CSP1 Iron
My singer magic press 4 iron comes on but the plate will not heat up. I turn it on one day and it just would not heat up.
Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
Jun 18, 2009 | Singer CSP1 Iron
Singer steam press csp-1 iron
heatman101
Mar 03, 2009 | Singer Electronic Steam Press Iron
Singer CSP1 Iron Logo
340 people viewed this question
Top Singer Irons Experts
Chance Miller
Are you a Singer Iron Expert? Answer questions, earn points and help others
