Question about RCA HD52W56 52" Rear Projection HDTV
Green picture on screen with no other images...
So when you say its fried there is no possible solution. What if i removed it from its main power source and tried some where else, what then?
    Genius:
  • 1,605 Answers
Nothing that I know can corrected the problem.
if you wish, you can start by checking see if you get parts for the TV. I mean all of it. once you located the source, then I would start replace the main source of problem.
I would see the total replacements are more than the new TV cost.
it is your call.
I would just go buy a new one.
Posted on Oct 28, 2008
When opening the shutter no image comes up on the LCD screen. The date, remaining image details are still showing however. If a picture is taken, it comes up as a light green screen.
sir,
digital cameras have an image sensor called CCD or C-mos if the camera picture is having problems with color this part may be faulty.
the picture previously taken (before this fault happened) must be fair, if it also bad then there may be problem with LCD or the main board.
Jan 26, 2016 | Cameras
Samsung 710v problem. It started out as "Not optimum mode" for which i applied the 50/47 ohm fix present around the web. It worked for around a year.
Not optimum mode refers to the resolution. If you set it to 2048x1024 and your monitor won't support that, it will give you this message. Remove the resistor. In Windows Control Panel go to display. Adjust your resolution to your preference in the table. Do NOT exceed the table. You may have fried your monitor with the resistor. Good luck.
Nov 04, 2014 | Computers & Internet
LC-40le550u no picture... green light on
if powers on and has no video and no audio could be the main board, but first try this :
take a flashlight, turns on the tv and try to "see" the image while light up the flashlight against the screen , if you "see" something you have a bad back light inverter board.
below the posible parts number :
MAIN BOARD : Sharp 9JY0140CTJ05100
POWER SUPPLY/ BACK LIGHT : Sharp 9JY0940CTJ05000
TRY TO LOOK FOR AT :
www.bostonrecycling.net
or ebay
thanks
Oct 09, 2014 | Televison & Video
Possibly fried screen
This is probable the lcd backlight inverter. If you have sound then look at the screen up close with a flashlight and see if there are images. If you can see images then the back light has problems and it is most likely the inverter.
Nov 18, 2013 | Toshiba 26LV610U LCD TV
Everything seems to work but nothing on the screen at all.
hold down the power lead? not quite sure i understand cause what it sounds like you have to do, is a bit of a jimmy rig. Most likely, in replacing the inverter, and this is uncommon but possible, if you are using the wrong inverter you could have possibly fried the screen(unlikely) or fried the display adapter(more likely). How old is the laptop? When you plug in the other monitor are you making sure to toggle between screens using your keyboard. if so and no picture.....video card is dead....and you are most likely out of luck as the cost to fix is more than the cost to replace the computer.
May 26, 2012 | Computers & Internet
I have an Element 32" flat screen tv model # ELCHW321 that i am trying to use as a computer monitor via vga to vga connection and am not having any luck. The tv says no signal. I have tried a newer laptop...
When you are using a laptop you have to press and hold down the function key and hold down the dual monitor key (either F5 of F8) for about 15 full seconds. The screen of your laptop should darken and the image should come up on the tv screen.
May 06, 2010 | Element Electronics FLX3210 32 in. LCD TV
Hello i have a lp690 suddenly the picture dissapeared no ligt in the lamp..It has run 350hours only the power button flashes(green) but no alarm..Should the lamp be changed????
you need to clean and resolder the edge connector on the power supply where it connects to the main board. on this series of prohector, this is a common problem. that and the yellowing of the image due to the frying of the light filter on the blue lcd panel (keep the projector clean and free of dust and you will avoid this, as there are no longer any parts available).
Oct 17, 2009 | InFocus LP 690 Multimedia Projector
Screen turns green
It could be the LVDS cable is bad.
Feb 10, 2009 | Vizio VO47L 47 in. LCD TV
The picture on my screen is green no other images.
you TV is fried.
something is burnning inside of the set. most likely the high voltage supply.
Oct 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
