Question about Cameras
Samsung Model S630 Lens will not retract into camera.
  • 84 Answers
Now don't take this the wrong way, but USUALLY what causes this is that the camera (lens) has received impact damage when turned on. In other words the lens barrel has been 'hit'. Sometimes you can check this by holding it up and looking to see if the lens (when turned on) is straight. (but not always)
Posted on Oct 20, 2008
  • 1,550 Answers
Remove the battery and insert new battery and check if it is working .
If it is not working then you gently tap on the sides of camera this will work .
Need manual for samsung model s630 camera?
Aug 25, 2010 | Samsung Digimax S630 Digital Camera
The lens is stuck out and is slightly bent and it wont switch on. the light comes on and then switches off. it was dropped
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 02, 2009 | Samsung Digimax S630 Digital Camera
S630 won't turn on
Openings the lense is the last thing you want to try. If you dropped your camera, you may have to. If you did not drop your camera, some dirt somhow got on the sides of the lense and they prevent your lense from closing or opening 100%
Try this first
turn it on and the same time pull the lense out. Your lense may not be open all the way out. OR
Clean the side (outside) of the lense. While turning your camera OFF, push on the lense in NOT too hard. Try that a few times, If the lense retracted 100% or near 100%, just push the lense in a little harder untill it is 100% retrected. Turn it on, It may work now.
Good luck!!!!!!!!!!
Good Luck!!!!!!!
Jun 11, 2009 | Samsung S630 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Lens stuck in "out" position. Won't retract.
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
Mar 22, 2009 | Samsung Digimax S630 Digital Camera
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
Digimax 430 camera won't turn on
If your lens is open and the camera turns off after those dreaded beeps, I have a fix for your problem. Basically, for this model of camera, the lens first pushes out a bit and then it retracts into the camera. Well, my lens got stuck on the pushout and it prevented the camera from turning on. I used some finger pressure and wiggled the lens a bit. Then I turned it on and it retracted to where is was supposed to be to take pictures. Then I turned it off and it retracted into the camera. Problem solved!
Nov 05, 2007 | Samsung Digimax 430 Digital Camera
Cameras Logo
63 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
