Question about Mitsubishi WS-48311 48" Rear Projection Television
Component color turns yellow
When my Mits WS-48311 is in component 1 or 2 the color is fine for alittle bit then part of the color goes out and everything turns mostly yellow.Once I change out of the component to ant. the color is fine. However, after a while I go back to the component the color is back to normal. I have tried adjusting the contrast with no avail.I tried changing the blue and red with no luck. I also have the TV reset to factory spects and still did not correct the problem. Any ideas on what the issue could be?
  • Joshua Davis Jul 01, 2006
    It is hard to discribe. I guess it is like the color goes out but not completely. It is like the screen has a tent to it but not black and white.
  • Anonymous Nov 18, 2007
    I am having the same problem, but it looks like I put on a pair of yellow sun glasses... I still see some colors, but there is a yellow tint to the entire screen
    President:
  • 3,130 Answers
When you say color. Do you mean gray scale like what if you turn off the color completely?? Does the picture look B&W? need to know this?
Posted on Jul 01, 2006
  • Lori K
    Lori K Nov 26, 2013
    yes the picture on the tv is completey black and white but the menu is color and when i turn on net flix and dvd they play in color too. think the kids messed with the remote but i have no idea what they pushed
How do I hook ws-48311 to hdmi cable
you don't have an HDMI input on this unit & will need to use the component input.
Oct 27, 2014 | Mitsubishi WD Televison & Video
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-48311 projection model. It started turning off for no reason and I would turn it back on while watching a program. Then it went off and will on come back on. Then you press the power button...
gtl545,
This model has a known defect. The power supply board and DM boards have failed electrolytic capacitors. No spares are available from the factory. Fortunately there are after market repair kits available. I have a tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which explains the problem as well as where to get parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 26, 2011 | Mitsubishi WS-48311 48" Rear Projection...
I have a WS-48311, lrss then 8 yrs old. When you turn it on the power light comes on and goes out in a few seconds.
Could be just end of bulb life. with it being 8 years old. get a manual for it and look in there what is suposed to happen at the end of the bulb life.
Aug 25, 2010 | Mitsubishi WS-48311 48" Rear Projection...
My WS-48311 has a pink screen for all imputs. Ive tried everthing and still wont go away. It does show it is in 480i in upper left corner and I cannot change that to 1080i. Any ideas?
You can't change the resolution higher if that's what the broadcast is sending. You can try the RGB component inputs, that will leave it wide open for what ever they send and max resolution your set can handle.
Nov 10, 2009 | Mitsubishi WS-48311 48" Rear Projection...
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
Need to sell working parts from a Mitsubishi WS-48311
Hi, I seen your Post. I would like to buy parts off from you. How can I get in contact with you.
Dec 02, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Bad color
Turn the color level all the way down and see if you have a good black and white picture. If your screen isnt black and white it should have a predominate tint to it. then turn the screen control for that color down to achieve the best black and white picture. then adjust your color level that should help.
Jun 13, 2008 | Mitsubishi WS-48311 48" Rear Projection...
S-Video on the blue screen
menu has input selection to turn on/off or name video inputs.....T.
Oct 24, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi WS-48311 48" Rear Projection Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
