My Sony Trinitron TV does not show picture. The standby light comes on and blinks 7 times then pauses and then blinks 7 times. This continues to repeat itself. TV never shows picture or sound. Light just continues to blink.
  • 320 Answers
The usual cause of this is the sensing IC (there are 2 of them) on the power supply board. Sony usually recommends pulling the board and returning it to them for service.
Posted on Oct 20, 2008
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black screen model kv-27fs200 there is sound just no picture stand by light blinks 4 times the pauses and does it again
4 times standby light blink shows problem in vertical deflection section of TV.
Please check and replace vertical output IC in main board.
Thanks.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV not turning on!
u need to change the lamp...same thing happened to me then i bought a lamp on ebay for $75n replaced it n now it works fine
May 28, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
this is almost certainly a ht proplem chech ht transistor by removal then turn tv on it should if so replace transistor be carfull high voltage may be still present on capacitors
Mar 30, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony trinitron
Need a little information here...
1. The TV remains on, yet there is no picture and no sound? Or does the TV turn off altogether?
2. Are the blinks constant and continuous? Meaning, does it blink two times, pause, blink two times and go on and on like that?
3. Can you turn the TV on? Or can you not get it to turn on?
Answer those questions and I can give you some more information or send you to the place where you can get it.
Nov 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony trinitron fd no picture, no sound
IC 701 in short. It's the video amplifier situated on the crt pcb TDA6108JF. replace it.
Dec 05, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
