Question about Karcher K2.26 Electric Power Washer
Not working plug into 240 v instead of 110 v The appliance overheated What problems need to be resolved?
  • khalawan555 Oct 23, 2008
    Thank you, Same answer expected. I am opening up.Regards
  • 92 Answers
Dear Khalawan555,
All you did is damage to the electric part of the machine. This mostly means that the electric motor is damaged. But if the machine is recently bought, you still have the pump system all intact.
All you need is a new electric motor or if possible, rewinding the old electric motor.
Check if this is worth the money. In my expirience, changing an electric motor is more cheaper then buying a new machine. Very important if you decide to buy a new machine try to buy the same model, because you will have plenty valuable spares available from your old machine.
Regards,
MG.
Posted on Nov 05, 2008
    Champion:
  • 242 Answers
You most likely destroyed the pump. But if you are lucky, you can open the unit and look for a fuse. It will be on the circuit board in the unit or possibly in line with the power wire. It will be a thermal fuse that is wrapped in a teflon mesh cover. If there is no fuse, then chances are the unit will be a loss unless you know someone handy in electronics.
Posted on Oct 23, 2008
I have a older boze disc player which I bought in the U.S.. It has a U.S. Two prong plug. Can it run on U.K current or do I need converter as well as a two prong strip?
It depends on the voltage the disc player was designed to work with and there should be an identification label somewhere on the outside stating the voltage and the current it requires.
110/120 volt AC supplies used to be common around the world as did local direct current supplies but 220/240 volt AC supplies are gradually becoming the international standard.
lots of appliances used to be truly universal but as local direct current supplies are now virtually extinct, modern appliances are either dual voltage or single voltage.
Many small and portable appliances have been produced to work on either voltage - mostly selectable by a barely exposed switch and sometimes requiring adjustment to be made by removing a cover plate. Modern electronics has sometimes provided an automatic adjustment.
Most larger appliances are a single voltage type designed to work where they are sold. The information you require is contained in the instruction manual for the appliance and on the identification plate.
If your disc player is suitable for only a 110/120 volt AC supply you will need a small auto-transformer to make our 220/240 volt AC supply suitable for use.
If your disc player will operate on our voltage, all you will need to do is cut off the 2-pin plug and fit a British 3-pin plug and fit a suitable (3 amp) fuse.
Oct 01, 2016 | Televison & Video
CAN a 4 prong plug be change to fit a 3 prong so it will fit my 3 prong receptical
Hi Anthony:
A 4 prong plug is intended to handle 220/240 volt and also 110.
It has:
- Red and Black - 110 each 220 total
- White (neutral)
- Green (ground)
You will need to shut off the circuit breaker for your receptacly and then determine what power supply you have available.
You MAY be able to change your receptacle to handle your appliance.
I would NOT change the plug on your appliance as it needs both the 110 and 220 functions.
If you are not ABSOLUTELY SURE what you are doing, get an electrician. Not doing it right could start a fire or present the danger of electrical shock. WHICH HAS THE POTENTIAL OF KILLING SOMEONE.
Cheers.
Jan 04, 2016 | Roper Washer Timer Control 3351734D A E B
Put 240 volts into us hd dvd player
Fried. Some devices will auto negotiate or have a voltage switch. Simply look on specs.
Nov 22, 2012 | Computers & Internet
What is the standard plug for stoves newhome el916. Is it the general 13A plug
I can't find an online manual for the model of the appliance you are talking about, so I'm unable to figure out the wattage it draws. Nor do I know where you are in the world and the voltage you are running at, so I can't tell you straight off. But I can tell you how to figure it out very easily:
I imagine that know what your main power supply voltage is (either 240 volt or 110 volt).
You can look at the appliance and there will be a data sticker with the wattage rating on it somewhere (or it will be in the install/Owner manual).
Now you have these 2 bits of information we can do a simple sum:
Watts divided by Volts = Amps
Therefore example calculations look like this:
If you have a 500 watt appliance on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
An appliance with a 750 watt motor on 240 volts: 750/240 = 3.12 so use a 5 amp fuse
A 2KW (2000 watt) appliance like a hot air blower on a 240 volt system: 2000/240 = 8.33 amps so use a 10 amp (or more commonly 13 amp) fuse
A 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
A 1KW (1000 Watt) appliance at 110 volts: 1000/110 = 9.09 amps so use a 10 amp (or more commonly 13 amp) fuse
etc etc etc.....
If the sum comes out below 13 amps, you can use a 13 amp plug. If it doesn't you need to hardwire it into a proper cooker supply.
Jul 29, 2011 | Stoves Ovens
I have 240 timer switch and I wana use it for 120 ? How can I do that?
if the switch is rated for 240, then hook up the same way but use the 110 black and white wire for 110 volts to switch, instead of the red and black wire for 240 . on 110 black wire is always hot and the white is the neutral wire. the best wire to use is 12/2 with ground.
Jun 20, 2011 | Water Heaters
It came with a american plug and when we put a converter to australian plug on it it only shows 220w instead of 240 which is what we have in australia. Don't want to plug it in and it blow up on me.
I think you mean 220 volts, versus 220 watts. The difference between 220 & 240 volt equipment is usually just a matter of nomenclature -- no significant difference in terms of operating the equipment.
The vacuum is 110 / 120 volt since it has an "American" plug on it. If the plug is swapped for an "Australian" plug (or adapted) and plugged into the wall, the vacuum will be connected to 220 volts -- this would destroy the motor.
You would need a transformer to step down the Australian voltage to 110 / 120 volts. If you plug it in without a transformer, it will surely burn up the motor.
More info, let me know.
Charlie
Mar 30, 2011 | Vacuums
I cant plug my 120v input vamp2 power adapter into a 110v output voltage regulator its dont works
I don't understand why you are plugging this into a 110 volt regulator.. If by chance you are trying to run this from 220 volt power, you DO NOT use a regulator or a converter intended to run hair driers and appliances. You need to use a step-down transformer from 220 to 110 or 240 to 120.
The V\Amp2 is a switching regulator and it will NOT like to be run from another switching regulator such as found in those cheap appliance type convertors.
Here is the type you need: http://www.world-import.com/tc-100a.htm
Jan 07, 2011 | Behringer VAmp 2 Power Supply
Need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Mar 29, 2009 | Craftsman Air Tools & Compressors
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Karcher K2.26 Electric Power Washer Logo
213 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
