Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 101 2GB usb
I have a kingston 101 2GB usb. when i formatted the device, the storage size went down to 18MB. what happened? can anybody tell me what to do?
  • 849 Answers
It shows that the drive gone bad, anyhow check virus......
Posted on Oct 24, 2008
Usb storage size went down from 8gb to 4mb
First, download this Toshiba flash drive format tool
http://softadvice.informer.com/Toshiba_Usb_Flash_Drive_Format_Tool.html
and use to format your pen drive again with this software.
Nov 06, 2013 | Computers & Internet
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Till yesterday I was using my Kingston DTI / 4 GB Pendrive properly. Today it is not detecting in any pc's. i have checked with different systems also, not detecting. i have checked with USB drivers also....
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system. Try connecting the device again, i think this should solve the problem.
Otherwise go to this site,,,http://en.kioskea.net/download/
and download HP USB Disk Storage Format Tool and you connect ur pen drive and open the software HP USB Disk Storage Format Tool and click start and select ntfs,,,
and now there is no problem for your pen drive
Sep 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston 8gb cards only show 1.87 gb and will
The 'FAT' file-system uses 16-bit arithmetic, and thus is limited to about 2GB in size.
The 'FAT32' file-system uses 32-bit arithmetic, and thus can easily format an 8GB device.
So, be sure to choose 'FAT32'.
Also:
Click Start
Right-mouse click My Computer
Choose Manage
Click Storage
Click Disk Management (local)
Does the card show a 1.87GB "partition", plus 6.13GB of "unused" space?
If so, then delete that "small" partition, and then create a new partition that "spans" the entire 8GB.
Then, FORMAT that partition.
Nov 27, 2009 | Kingston 1GB Secure Digital Memory Card
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you specify the correct path and the filename my USB devise having problem SKYMEDI USB drive 2GB and it cant...
Hi
try to format your kingston with
Following tool.(HP USB Disk Storage Format Tool )
from the site
http://www.softpedia.com/progDownload/HP-USB-Disk-Storage-Format-Tool-Download-123786.html
This tool allows you to format your pendrive either
in fat32 or NTFS
IN which NTFS is better
and also IT· Allows creation of a FAT32 volume larger than 32 GB.
An alternative is to format it in any linux
Oct 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston 8 gb data traveller suddenly became skymedi storage device.i cannot access it. can anybody help? thanks.
try maybe it is bricked or damaged, try downloading Pheonix products which can help u repair any usb damaged storage media, worked on my 8gig usb and nokia n95, or u can try googling flashing utilities for you flash
Oct 07, 2009 | Kingston flash memory card - 256 MB -...
Memory problem
Hi furgan_138,
Did it appear to compete the password creation successfully? When you create a password on these drives it actually splits the storage area into two peices. A public zone and a private zone (private zone is the area that is password protected). Perhaps you seleted as much as you could for the private zone and the 18MB is actually the public zone you are seeing. Try logging in and check what capacity you see on the private zone.
Kingston Tech Support
Dec 30, 2008 | Kingston Computers & Internet
512MB KINGSTON DATA TRAVELER BECOMES SKYMEDI USB DRIVE USB DEVICE..PLS HELP
I think that I have a similar problem (and a potential solution)
1. My thumb drive is 4GB "super talent", and I have used it for about 2years
2. Suddenly, it show up as "REMOVABLE" SKYMEDI USB DEVICE (!)
3. I tried "google" for answer... and did not get further
4. Finally, I righ click on "my computer" -> select "manage" the "computer management" MMC windows open
4.1 I tried the "Disk Management" and it still can not connect to it
4.2 I clicked on "Removable Storage" ... and then I "SKYMEDI..."
4.3. I righ click on the device and select "Task" -> "Free" (thinking ... what can be worst!)
4.4 ... sunddenly ... I see my drive back ... with everything on it....
I hope that this help (... I am guessing that the "removable storage" manager locked this device somehow)
Regards
Jul 07, 2008 | Kingston Technologies 512MB DataTraveler I...
How to format the microSD?
actually u shold format it by the device in which u are going to use. eg camera. This will enable correct formating for usage of this device.
otherwise their is a standard Sd format and u can use that to format
You can format the card by SD card Utility. SD utility is a format utility which is release from SD Association. It is a standard for all SD type card and will self determine the SD card's file system. Please kindly refer to the link below for SD format utility download webpage.
http://www.sdcard.org/about/downloads/
May 05, 2008 | Kingston 2GB Secure Digital Memory Card
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
217 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
