Wire color code
Black wire is ground, Red with 5a fuse is hot. Green/black is L Ground BTL, Grey /black is right ground BTL, the RCAs are left and right low level inputs. Then there is the 5 pin connector. It has a red wire for +12v, two black wires for input grounds, a green wire for left Hi input and a gray wire for right high input. If you install using traditional common ground high level, then you don't used the two BTL wires. Just connect the wires from your 5 pin connctor. If you use the low level RCAs for inputs, then you only need to connect the red and black from your 5 pin connector.(Plus the main red and black) Make sure the switched on the bottom of your EQ are set correctly. COM for common ground and LOW for RCA input or High for Green/Gray wire input. If you are using a floating ground the select BTL and connect the two BTL wires to the floating grounds of your stereo. There is also a line input adjuster so you can adjust your input sensitivity to match your reciever. I have the owners manual if you have any other questions.
Can you make some sort of diagram to see where everything goes? I have the js-234 but it has all the same wires it would really help thank you.
Sorry it took so long. I did not see the question until now. Don't know why the images don't show below. I added the important ones above. If they don't work try thishttps://www.facebook.com/ddrown/media_se...
