Question about Pioneer DVR-540HX DVD Recorder/HDD Recorder
Recording problem Whenever I set it to record it misses the last 5 minutes. I've checked the time on on all clocks but cannot fix this problem. Help please!
    Problem Solver:
  • 14 Answers
My solution is a simple one. I set the Record Time via "TIMER REC." on your remote for 10 minutes BEFORE and AFTER my desired program time.
Now it's a simple matter to EDIT to the program content I want.
Hope this helps you!
Posted on Feb 18, 2009
Changing the clock/internal time
The clock settings should be set to Auto so that the clock is set by the broadcasted signal; this will automatically update when the clocks change.
Note that Recording start and end times should be set to On Time to ensure that the broadcaster's start and end signals are used. If either of these are changed, the timing becomes manual, and functions such as Series Record are not available.
Mar 06, 2014 | Humax PVR9300T HD DVR
Setting clock
To set clock:
1. Press "Timer/clock button". The hour digit begins to flash.
2. Press (<< P.DOWN or >> P.UP) on the multicontrol to set Hours.
3. Press SET button. The minute digits begins to flash.
4. Press (<, P.DOWN or >> P.UP) on the multicontrol to set Minutes.
5. Press "Set" button."CLOCK OK" appears on the display. The clock stops flashing, and the clock timer starts from "0" seconds. If the clock is not set "AM 12:00" will flash instead of the clock indication. When the time has been set, TIMER/CLOCK can be used to operate the daily timer recording timer.
If you haven't the user manaul to your set with you now, send your email address to me by Fixya comment bos. I've the downloaded user manual to your set, and I'll send a copy of it to you by return mail. OK.
Jan 21, 2012 | JVC MX-D402T Shelf System
It stops recording a few minutes before the end of the programme
A firmware update is necessary with your Humax Foxsat receiver. Get into Humax site and update the device with latest firmware. OK.
Oct 20, 2011 | Humax FOXAT HDR DTV Receiver
Hi, Hope you can help me! When recording off the guide, programs finish just prior to the end by a few minutes cutting off the end of the program. The clock is set to the correct time, what can I do...
If programs run over when you are recording from your DVR, you have the option of having the recording last longer. We do this with ours, especially on live broadcast. You can find in the options for recording to extend the time. We always go over by five minutes so as not to miss the end of the show.
Jul 11, 2011 | Televison & Video
The time show late every single day..every day i must turn the right time..
Do you have your DVR set for automatic clock updates? I changed mine to manual clock settings because of problems with the new dates for Daylight Savings Time. Every few months I have to adjust the time by a minute or so if I find I am missing the intro to programs that I record. I also have to do the Daylight Savings Time shifts each fall and spring.
Nov 21, 2009 | Panasonic DMR-E55 DVD Recorder
Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Nov 26, 2008 | Panasonic PV-7451 VHS VCR
check time clock and did you push the power button off?
Oct 11, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Pioneer DVR-540HX DVD Recorder/HDD Recorder Logo
94 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
