Question about Dell A940 All-In-One InkJet Printer
Copier does not work
Copier used to work fine - now just a whining noise and nothing happens.
Seems to be scanning document all right but does not print
  • creeda1 Oct 20, 2008
    The printer works perfectly - just the copier has failed - Dell A940
  • Dell Master
  • 13,433 Answers
There must be a communication problem between the scanner and printer, the problem might require replacement parts, or atleast a closer inspection, I think its best you send this in for repair, hows the warranty and how old is it? you can generally buy a new multifunction scanner copyer printer for cheaper than the repairs might be.
Posted on Oct 20, 2008
  • Ekse Oct 20, 2008
    let me know if theres anything you need
  • Dell Master
  • 1,183 Answers
Kindly follow the following troubleshooting steps
http://tinyurl.com/65eopb
If after the same , the issue is not resolved, the only choice would be to replace the all in one printer.
Do keep me posted on the same
Thanks
Proton
  • Mandeep  Singh
    Mandeep Singh Oct 20, 2008
    Hi ,
    With the experience that i have on dell printers , the problem can only be with the printer. Try scaning the page using the Dell all in one centre program on the computer.
    Thanks
    Proton
    Sergeant:
  • 352 Answers
Hi creed,
Although the printer is working fine, there is an error in your drivers, new drivers will update all printer drivers and may clear the fault, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
    Scholar:
  • 84 Answers
Tell sumthing about the model of your copier
    Sergeant:
    Champion:
  • 200 Answers
Hi
tell me the model no and brand name. so that we can help clearly..
thank you
  • Thafa Oct 20, 2008
    hi
    try to restart the printer and then try it...
    thank you
    Genius:
  • 1,142 Answers
What about the printout does your printer part works fine ?
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
Hello, I have a Lexmark 204n, the printer is working porperly as well as the copier, but I can not scan any document. When I click on the Scan/Email button, then I chose applications and when I click th...
Make sure that the Scan driver is installed on your computer. You can get the scan driver from Lexmark's support site.
For further assistance, please call Lexmark Technical Support
May 31, 2011 | Lexmark X204n 4-in-1 Laser Printer
Problem with scanned documents using Ricoh Aficio 5500
IF YOU GO TO RICOH.CO .UK GO TO THE DOWNLOADS PAGE AND LOOK FOR DRIVERS AND DOWNLOAD THE LATEST DRIVERS FOR PRINTER DRIVERS THIS MIGHT HELP THE SCAN SETTINGS FOR PDF/TIFF ARE ON THE NEXT PAGE AFTER THE TEST/PHOTO.. THE GOBBLEDEE-GOOK IS BECAUSE THE PRINTER DRIVER IS EITHER CURRUPT OR YOU HAVE A MISS MATCH IN DRIVER LANGUGE BETWEEN THE COPIER AND THE COMPUTER..TRY THE RPCS DRIVER FRO PRINTER.. THIS IS THE RICOH DRIVER AS APPOSSED TO THE PCL DRIVER WHICH IS A GENERAL DRIVER.. LET ME KNOW IF YHOUNEED ANY MORE INFO..
Aug 06, 2009 | Office Equipment & Supplies
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
My Dell copier model# A920 will not copy manually
If you want to scan you will need to connect the device to a computer. For copying, place a document to be copied on the flatbed scanner and press the color or black button (as appropriate).
Jun 02, 2009 | Dell A920 InkJet Printer
Software loaded when first bought. Tried scanning a picture from the control panel but nothing happens?
Try to copy a document from your printer. If it works Click here and follow instructions to resolve the issue.
May 24, 2009 | HP PSC 1410v All-in-One Printer
Xerox WorkCentre 7232 will not Scan to PC
Your error code usually means: Scanner can not find the specified folder/storage location
-wrong document path
May 21, 2009 | Xerox Office Equipment & Supplies
Scanning
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&lang=en&product=90792
Issue When the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
Oct 04, 2008 | HP Officejet 4110 All-In-One InkJet...
We have a Xerox M20 Copier/Scanner/Fax/Email which we have always used strictly as a copier. We need to use it as a scanner, to reduce paper in the office and access/share documents electronically. I...
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Sep 22, 2008 | Xerox Office Equipment & Supplies
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
