Question about Lasko 3720 Floor / Box Fan
Box fan Ok I now own 2 box fans the won;t work, they worked for a bit, now thier toast. the last one got a ballon string sucked into it, and now it won;t turn on. is the motor fried now? or is there a relay switch or something?
  • 3,130 Answers
Re: Box fan
There should be whats called a thermal cutout or what some folks call a tempature fuse. Its inside the motor and Ive fould lots and lots of fans in the trash and simply jumped the thermal fuse with another one and they work great. Now you of course will have to take off the blade with the unit unplugged ans then take apart the motor. It will look like a small cylinder or bullet. there should be a marking on it that tell you what temp its rated for. Just be carefull as there still is the voltage hazards with a fan if it gets plugged in while its apart. Good Luck
Posted on Jul 01, 2006
0 characters
3 Points
My fan won't turn on a ballon string got stuck and I took the string off and now it won't turn on
You probably burned the motor up.
Or.. there is still more string in there. Take the fan apart, take the motor out... try to turn it by hand. Does it turn? If not, double check for more string flattened out and stuck btwn the spindle and the machine.
Smell the motor for the distinct smell of hot/melting, etc.
Oct 29, 2013 | Patton Electric U2-20 Box Fan
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Fans
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
I have checked the power breaker and it is ok but the lights and fan do not work is there a fuse in the unit
the connection at the ceiling plate and box may have come loose, remove the cover plate and check for power in the box, ( black wire in the ceiling box should show power, white is neutral) if you have no power there, check the switch at the wall that controls the ceiling box
Jun 23, 2011 | Hampton Bay 24002 Ceiling Fan
My Bathroom Fan (Nutone) is sucking very little but blowing quite abit from around the fan asembly meets the cutout in the ceiling. The vent outside is blowing out quite a bit of air, (more than whats...
if there is no suction my question back you would be do you have a leak around the box in the cealing did you use calking material when you installed it? let me know so I can help. Also do you have a window open to see if the room breaths? Just some ideals Reply back for more help.
Aug 31, 2010 | Broan-NuTone N-763RLN Combination Light...
it probably slowed or stalled the motor down so far that if its variable speed it burned out the speed control triac in the speed control,you need to access the speed control board and find the problem,otherwise if the motor isn't harmed too bad,direct wire(bypass) speed control and run on high
Oct 11, 2009 | Aloha Housewares Breeze 29" Tower Fan
How do you take off the spinning part off of a lasko fan?
Just hold the blade and use a sharp knife and cut the string. It's really not that hard!
Jul 28, 2009 | Lasko 3300 Wind Machine¿ Floor / Box...
Fan and remote not working
If you haven't already done so, replace the remote's battery with a brand new one . Make sure the replacement battery is NEW AND UNUSED, AND WAS PURCHASED RECENTLY, SO IT IS FRESH. Make sure it is installed properly, making good electrical contact, and the proper polarity is observed. Was the remote dropped, sat on or stepped on? Was a liquid spilled on it? Did your pet chew on it? Are any of the buttons loose or stuck? If the remote seems ok, try removing 120 volt power from the fan by turning off the circuit breaker or fuse an your homes main electrical service box. Wait 30 seconds, then turn 120 volt power for the fan back on. This may reset the speed control in the fan unit. If it does not cure the problem, consult a professional electrician, or replace the fan, whichever is more cost-effective.
wait 30 seconds and turn 120
Jul 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Lasko 3720 Floor / Box Fan Logo
734 people viewed this question
Top Lasko Fans Experts
Arcadian Duran
Arcadian Duran
Level 1 Expert
Are you a Lasko Fan Expert? Answer questions, earn points and help others
