Question about Dell A940 All-In-One InkJet Printer
Dell A940 all-in one printer does not copy
Copier was working fine - now just makes a loud noise and produces nothing!!
    Sergeant:
  • 352 Answers
Hi, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
Xerox grinding noise
the bearing on the motor or the rotating path must have damaged..
replace them
Jun 02, 2008 | Xerox WorkCentre Pro 215 Printer & Copier...
Hi if my printer a940 is not conected to the computer can it copy a paper?
Yes, you can. Press Number of Copies repeatedly until the number (any number 1-99) of copies you want to make displays, or press + or - to scroll through the number list. Press Color or Black. The printer is working when the display reads COPYING.
Taken from the user manual http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Jan 15, 2011 | Dell A940 All-In-One InkJet Printer
Cant copy from web to home copier what am i doing wrong??
Usually the format is the problem,I usually take a screenshot,paste it to paint,then print from there.Or copy and paste the info to wordpad and print from there.
Sep 20, 2009 | Dell A940 All-In-One InkJet Printer
Dell a940 printer error 50 c tried without
I had this same problem. I solved it by cleaning the bay where the cartridges go with some 100% Isopropyl Alcohol. Then i just replaced the cartridges with new ones and it worked fine!
May 11, 2009 | Dell A940 All-In-One InkJet Printer
Cs-1510 makes loud high pitch noise when copying
loud noise is usually coming from the laser unit. if you can ger to it, lubricate it's polygon motor shaft with some oil. It usually works fine afterwards. It is a bit of a hassle to remove the laser unit.
Mar 11, 2009 | Copystar CS-1510 Copier
Changing ink cartridges?
I have a dell printer, scanner, fax ect.
The printer and scanner won't work now. Keep getting message, " hardware errpr 0502, when printer starts up, gives a loud click noise.
How do I fix?
Mike Murphy mmurphy8015@yahoo.com
Jan 04, 2009 | Dell A940 All-In-One InkJet Printer
Dell A940 copier works fine but will not print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dell A940 Color Ink Problem
Do check the option and make sure that you have not inadvertently set it to black only- This could be computer wise or on the A940 panel. If you are sure all is well here Remove the scanner software and reinstall. Email Dell to See what they have to say
May 08, 2007 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
