I own a Peavey amp #kba 100. Speaker may be blown or loose. How does the case disassemble so I can get to the speaker to determine the problem? Thanks for your help!
  • 86 Answers
There should be Screws on the back of the unit witch takes off the whole back panel to were you see the back of the speaker an the wiring in side the amp, on the speaker mounts should be somebolts or clips to were the speaker will slid out from the back
Posted on Oct 20, 2008
Peavey Problems
Check speaker impedance or disconnect speaker leads, then use a 9V battery to verify cone movement and if this test is ok, then go inside the amp, if there's no fuses blown check opamps supply voltage which should be -15V at pin-4 and +15V at pin-8, let me know your results to help improvement.
May 21, 2013 | Peavey Electronics Peavey Max 112 Bass...
2005 745i front passenger side speaker making a cracking sound
Either the speaker is blown (most likely) or there is a loose connection to the speaker, or the amp is bad. The connections to the speaker are pretty tight and it's unlikely it came loose unless you recently had some work done near the head unit or the radio, and if the amp works well for all other speakers it's probably OK. Unfortunately you can't fix a blown speaker but you can replace it and you can find a new one online for less than $100
Feb 19, 2013 | 2005 BMW 745Li Automatic
How do I go about disassembling my peavey 6150+112 combo guitar amp to the point where I can replace the 12" driiver for a better one.
Most Peavey speakers you will have to just remove the grille in front of the speaker. These usually are held by Velcro like fasteners that you must carefully pry the grille out. That will give you access too the screws holding the speaker rim. Be aware that there are different sizes of speaker rims and mountings for the "same" listed size speaker. Also use the same impedance speaker as the original one or you MAY find you have less power OR blow your amp out.
Jul 30, 2011 | Peavey 6505+ 112 Combo Amp Combo
I was playing then all the sudden it sounded like it shorted out. The power is still on and the tubes fire up but the "STANDBUY" switch isn't lighting up when in on position. Please help.
The speaker is blown. Did it smell a little funny when this happened. Sometimes they get a faint burning smell when they blow. Some Peavey amps especially older ones are known for letting DC current slip through to the speaker and blows it immediately. Most of the rest of the amp deals with that pretty well so I'm not quite sure what going on with the standby switch. Probably just a blown bulb.
Jul 16, 2011 | Peavey 6505+ 112 Combo Amp Combo
My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
I have been using two Peavey Pro 15 Mk ii 300 Watt Passive 15" Speakers with two additional speakers on the output side and i notice one of the peavey speakes wasnt working! i then realised i had the...
Passive speakers with 1/4 inch jacks do not define either as input as they are wired in parallel...
Assuming the speakers you added were each no less than 8 ohms this should NOT have overloaded your amp.If you have no sound you have probably blown your amp some way.
Note some amps can be blown if they are on and EITHER side of the speaker cable touches a ground. If the amp is running and a 1/4 inch plug is pulled, it shorts and can blow the amp.
Jan 17, 2011 | Peavey PR15 400w PA Speakers
Whats the wattage of the bulb used in peavey sp2 crossover, my sp2 peavey speaker bulb is blown
The lamp is an "1156" lamp... replace with that part number. Here :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=524517&k=lamp%201156
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2010-ND
or this one (1.85 amp, trip 3.7 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2013-ND
Jan 11, 2011 | Peavey SP2 PA Passive Speaker
The blue and red cable came loose on my peavey pr 15 neo 2 way speaker
Put the red on the + side and the blkue on the - side. SECURE the wires so that their weight does not pull them loose again. You can pop amps when speakers come loose...
Jan 02, 2011 | Peavey PR15 400w PA Speakers
PEAVEY XXL AMP HEAD PROBLEM!!! NEED HELP NOW!!!
Hi...
Do you have the Impedance switch set for the right cab?
Are you using a guitar cord to connect to speaker cab ?...If so, dont. Use a speaker cable.
Is the damping switch loose?
Jun 23, 2010 | Audio Players & Recorders
PEAVEY djs4 speaker QUESTION
If a speaker is "blown", there is normally an open-circuit in the voice coil, therefore it emits no sound at all. Can't discount a loose wire, but blown HF drivers are very common.
Dec 31, 2007 | Audio Players & Recorders
80 people viewed this question
 Grubhead
Grubhead
