Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV WON'T COME ON
Watching a movie and tv just went out.Tried to unplug and turn back on but no luck then had someone to check fuse it's ok also. Green light on the power botton flashes when trying to turn power on.
  • 1,476 Answers
If the fuses are good and the on indicator lights you could have a short in the power supply, the high voltage section or just about any part of the circuitry. The most common problem is the high voltage. If you know TV safety and how to check transistors, unplug the unit and check the horizontal output transistor. If it is shorted replace the transistor, flyback and HV divider. If this does not solve the problem you will probably need a repair tech as this symptom could be a short anywhere in the unit. Good luck and remember to be safe.
Posted on Jul 12, 2006
My 42lh30 lg tv was on the kids where watching movie on xbox then the tv and xbox just turned off. and will not come back on. the xbox is working. but there is no red light saying the tv is getting power....
Possibly you've had a power cut & a fuse associated with the TV has blown. Have you checked the fuse in the TV plug? If that's ok then probably a fuse internally in the TV has blown or something more serious has blown in the power supply
Aug 25, 2013 | LG M4201C-BA 42 in. HD-Ready LCD
TV won't come back after pushing wrong button on remote.
Try unplugging the TV.. After you plug it back in it may be OK. I had a similar problem were I could not turn on the TV (JVC). The owners manual specified in the troubleshooting section to unplug for 1/2 hour. I left it unplugged overnight and the next day plugged it in and it was fine.
May 21, 2013 | Televison & Video
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
A small amount spilled on top of entertainjment center dripped down an went into the back of my zenith 72 in tv i was watching a vcr movie and suddenly lines went across screen and then it shut down and...
Your tv set suffered short circuit problem in the power supply area since it fails to turn on. Try to open the cover of the tv and check for the damaged parts like a busted fuse or shorted power transistor and replace it.
Dec 01, 2010 | Zenith Televison & Video
TV was on. Now it is off and will not turn back
more than likely blew a fuse on the power supply take the back off and check the fuses with voltmeter
May 20, 2010 | Samsung 50 in. Plasma TV
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
My 32' Magnavox LCD TV won't turn on
it sounds like the internal fuse blew out it normaly a 5 to 15 amp fuse the you can pick up at any auto parts store if you are in the philladelphia area i have someone who can come fix it for you
Dec 02, 2008 | Televison & Video
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Tv went off.
i have the exact same problem except with a different tv model.and i cant get help.
Jun 01, 2007 | GE 19GT357 19" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
