How to remove the base of a LG tv (Model 47LB1DA)?
Tried to remove the square base of a LG tv in order to hang on the wall.
I removed all the screws and still it will not comw apart.
SOURCE: Dynex TV
You have to take the back off.
Posted on Sep 21, 2008
SOURCE: removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
SOURCE: how to remove base support from PROSCAN LCD TV( model 26LB30Q)
Remove the srews under AUDIO-L/R and HDMI-1.
Posted on Mar 30, 2009
  • 187 Answers
SOURCE: the screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
Posted on May 27, 2009
SOURCE: We can't figure out how to remove the base on our
look at the rear of the tv there are four phillips head screws holding the base on unscrew them and lift the base off
Posted on Jul 18, 2009
HOw do I remove the base from a LG 32LK330 flat screen TV
Lay the tv screen facing down on something soft like your sette or bed so the base is hanging over the edge.
At the back you should see screws on the base, if not visible they will be under a cover which should prise off
Dec 31, 2013 | LG 32LK330 TV
How to remove base so it can be wall mounted
Put LCD TV on a pillow, with screen resting on the pillow. Now the base will be free in air. Then remove screws at the back of TV, where base is joining. You might need a screw driver with magnetic head to remove screws. After removing screws, slide the base clamp out from the back of TV, and you are done.
Nov 01, 2010 | LG 32LG30 32 in. LCD HDTV
How to remove the base plate so i can mount it on the wall
Most LCDs have anywhere from 4 to 6 screws holding base on. Lay it on a table on its face with base hanging over the edge, using a towel or blanket so you don't scratch it. The screws should be just above where the base goes into it. remove them and the base should pull right out. Good luck!
Feb 23, 2010 | LG 47LG60 LCD TV
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
We can't figure out how to remove the base on our new 50" Sanyo Plasma TV so we can hang it on the wall...HELP!
Apr 15, 2009 | Sanyo DP50747 50 in. Plasma TV
Taking off stand from LG tv to mount on wall
I work on TVs and the amount of screws in the back is crazy.
find a place to lay the tv down on the screen, use some pads and a blanket to prevent scratching or cracking screen. your couch or bed may be a good choice, but make sure it is stable. let the stand hang over the edge with no weight on it. now look for 6-8 screws per per leg of the base. depending on the size of your tv. these are usually the larger screws on the tv and attached to the frame of the TV. remove these screws in the base and slide the base out.
your manual should also have a brief description of base removal as well. dont worry about taking out the wrong screws, you can put them back in it is not the right screw. with tv on its face, no parts will fall out. hope this helps.
Apr 08, 2009 | Televison & Video
I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Oct 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Dynex TV
Sep 06, 2008 | CTL Nexus NX3200 Television
Taking the base off
Please tell me what TV it is and give me a model number, once i know that I can be of easy help.
Have a great day
Jun 04, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
268 people viewed this question
Top Televison & Video Experts
