Question about Hotpoint WMA58 Front Load Washer
Over filling with water
My machine isn't going through the cycle properly. I set it on D and after initially starting off fine the pre-wash light comes on and I have to push the start button for it to continue. In addition to this, it is over filling with water.Help!
  • 641 Answers
There are two reasons could cause washer's overfilling. - A defective water entrance valve - Water supply to the machine is done through an electromagnet valve,loocated at the water pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! and to close water main tap to the machine. In case cleaning doesn't help, you should replace the valve. Water switch level - A diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. Open the rear panel, find the device and clear first any obstruction in the tube.In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it will not react, you should replace it. Good luck !!
Posted on Jul 02, 2006
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Wont spin and the front indicator lights are going from pre wash to end in a night rider fashion
try checking ur door switch may also want to check the water pressure switch which signals the machine to go into wash after the fill cycle
Feb 11, 2015 | Hotpoint Aquarius WMA56 Front Load Washer
My kenmore 400 washing machine isn't filling with
Check to be sure the drain line is higher than the tub.
Nov 20, 2012 | Washing Machines
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine tripped main fuse breaker, now won't work
Yes. It may be an internal safety fuse or switch. RJ
Sep 29, 2017 | Candy Washing Machines
Kenmore 90 plus won't fill on regular orpermanent press cycle.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
Mar 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Sep 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint WMA58 Front Load Washer Logo
178 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
