Question about Whirlpool RBD305PD Electric Double Oven
Neither oven will come on
After coming on and preheating Saturday, the upper oven went off and the lower wouldn't work either. Control paned was blank, but interior lights were on and pushing control paned buttons resulted in beeps. Turned off breaker for 5 minutes to reset and upon retry, the fan came on for maybe 5 seconds and then went off. Nothing else changed. Any suggestions?
Thanks.
  • 750 Answers
Hello kybattey
Welcome to Fixya.
You said, After coming on and preheating Saturday, the upper oven went off and the lower wouldn't work either. Control paned was blank, but interior lights were on and pushing control paned buttons resulted in beeps. Turned off breaker for 5 minutes to reset and upon retry, the fan came on for maybe 5 seconds and then went off. Nothing else changed. Any suggestions?
You say the ovens went on and then later cut off.
Does the clean mode work?
Try the clean mode and see if it goes on.
Assuming it will clean!
Since the Range will clean you have confirmation that the proper power is reaching the range. It also verifies that the elements are in working condition. You will need to check the high temperature limit switch and the door latch mechanism. If either of these is defective, the bake and broil function will not operate properly
Let me know how it goes.
Waiting your response.
Huuum
Please remember to leave a rating when done!
Posted on Oct 21, 2008
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Preheat not working in oven
When the element went it also took out the contactor..
Check out this tip...
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Apr 10, 2010 | Ovens
The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Nov 27, 2009 | Thermador SC302T Electric Double Oven
I have a Jenn Air ww2711w0 double oven. The Lower
Your t-stat or control board could be out on this unit. Can you check your t-stat and see if it's working alright? If it is, it's probably your board. Hope this helps~!
Aug 20, 2009 | Ovens
Jenn-air dbl oven WW30430B. Lower oven doesn't work anymore. Try to pre-heat - get F2 message. This started a year ago. Shortly after onset we had a hurricane and were without power for 2 days. When power...
HI. the oven control will interrupt normal actions if it senses an abnormal oven temperature. this can be caused by a faulty RTD(temp sensor), and, also, a faulty relay board if present.
Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness to make sure it is in good condition.
Aug 04, 2009 | Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Whirlpool RBD305PD Electric Double Oven Logo
225 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Richard Roth
Richard Roth
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
