Question about Sharp AL 1631 Copier
H3 ERROR CODE SHARP AL 1631
I REPLACED THE FUSER LAMP AND ERROR CODE STILL BLINKING H3.
  • PaulAnt Jan 14, 2009
    I think it helps, we have an older Sharp AR-350 with taht error code. Is it worth fixing?
  • Anonymous Mar 16, 2014
    Our church copier is flashing h3 what dose this mean and how can I fix it. thank you
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Posted on Oct 20, 2008
Al 1217 error code H3
Heat roller abnormally high
temperature
Check the heater lamp blinking
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness. Check the MCU PWB
thermistor input circuit.
When the lamp lights up instead
of blinking:
Check the lamp control circuit of
the power supply PWB and the
MCU PWB.
Clear the trouble with SIM 14.
May 07, 2014 | Sharp AL-1217 Copier
What does code H 3 mean when the copier is turned on?
A H3 code means that there is a problem with the fuser unit. You can try to clear th code in service mode, but it may come back. You may have a blown thermister or thermal fuse or the fuser heat lamp. Good Luck
Aug 26, 2010 | Sharp AL 1631 Copier
AL 1631 Grayscale Copier: letter h is blinking in the display unit does not ...
all the codes with(H4,H3,.......)can be removed by simulation 14
May 16, 2010 | Sharp AL 1631 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
I have error H 2, what to do?
This error indicates: H2-0 Fusing unit temperature error
Unless you are technically capable, you will want to have a qualified technician diagnose and repair.
If you want to try and diagnose it yourself, follow these directions.
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
Feb 03, 2010 | Sharp AL-2030 All-In-One Laser Printer
We have a code H 4 blinking model AL-1631 AL-1641CS
Please verify your fuser parts components,the heater lamp,thermistors and thermofuse.Your heaterlamp or the thermostat is in open circuit or the thermistors circuit is defectly.
Dec 11, 2009 | Sharp Office Equipment & Supplies
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
Oct 29, 2009 | Sharp AL 1631 Copier
Sharp ar-c330 with an error code of H4-01. Any
The fuser temperature is low.
Use sim. 5-02 to check blinking of the heater lamp.
if it blinks normally check the thermistor and the harness.
If it not lighted check the heater lamp and thermostat if its defective replace the heater lamp or the thermostat.
Jun 10, 2009 | Sharp AR-C270 Color Copier
Sharp AL 1631 Copier Logo
1,156 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
