Question about Lightning Audio LA1.300.2 Car Audio Amplifier
AMP not workin
I have this lightning audio LA1.150.2 Amplifier, the problem is that when I hook up all the cables and I put the fuse in so the amp can turn on, the red light sing of "protections" turns on... S i put new connections on my car and still can't make it work... If you have a solution please let me know I will really appreciate from you.... thanks for helping me out
  • Anonymous Nov 11, 2008
    protection
  • 22 Answers
Have you tried bridging 12 v supply to the remote wire to see if it switches on if it doesnt you either have bad earth or amp is faulty
Posted on Oct 23, 2008
Lightning Audio s4 300 Car Audio Amplifier
Make sure the remote turn on cable is connected correctly and fuses on the amp are not loose. But first off jump power from the power terminal to the remote terminal to see if it even turns on. if it does not then the problem is something blown inside the amp. Is there a fuse under the hood? if so make sure it is not blown.
Mar 30, 2014 | Lightning Audio FF150.2 Car Audio...
Hi, I own a lightning audio B300.4 amplifier, it is hooked to battery and grounded to boot with same. Remote cable from headunit is hooked up. All of these cables are in the right places and nothing else...
sounds like amp is grounded. use a multimeter with ohms and test from pos to neg, should be o.l if there is any reading or resistance there the amp is grounded and junk
Feb 19, 2010 | Car Audio & Video
Lightning audio b150.2 as soon as +12 is hooked up blows 25 amp fuse and the c2 1000uf/35v capacitors blow???????
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you.
Aug 25, 2009 | Lightning Audio PC2 Capacitor Car Audio...
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
RCA CABLES
RCA cables are the best way to get the audio from your head unit to the amp. If your head unit doesn't have RCA outputs, you might be able to use the speaker outputs of the head unit to connect to the "high power" or "high level" inputs of the amp, if the amp has such inputs (check your manual).
Mar 23, 2008 | Lightning Audio LA1.300.2 Car Audio...
Lightning audio B300.4 amp protect light
The most likely reason for it to go into protect is shorted output transistors.
Jan 16, 2008 | Car Audio & Video
you need to get a fan for it because it does not come wit one and when you get the fan you have to hook it up from the inside by taking the torture tested/bolt sign off and look for a small white pug to attach it to
Dec 08, 2006 | Lightning Audio Bolt B2.150.2 Car Audio...
Amplifier
Then it's a bad ground. Where did you ground the ground cable to? Is it tight, free of rust, clean, and most importanly, bare metal and free of paint?
Oct 23, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Amp cuts off
So you have an EQ and a Pioneer amp you're trying to hook up to each other? And only some Stinger RCA cable works? And when the lightning audio RCA cable is hooked up, it doesn't turn on? The amp isn't grounding itself through the RCA cables, is it? Check your ground wire and make sure it has a clean contact that's free of rust or any paint that might be in the way. Otherwise, the RCA cables should have nothing to do with an amp turning on or not.
May 07, 2006 | Pioneer GM-X324 Car Audio Amplifier
Lightning Audio LA1.300.2 Car Audio Amplifier Logo
121 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
