Question about Intertherm Heating & Cooling
OUR HEATER IS NOT WORKING IT TURNS ON BUT IT IS BLOWING COLD WHAT DOSE THAT MEAN? IS IT BROKE?
  • 750 Answers
Hello me_ow_2007
Sounds like the thermostat is broken.
Huuum
Posted on Oct 20, 2008
Heater doesn t work
Your control panel might be broke..
Sep 25, 2013 | 2002 Pontiac Sunfire
1990 toyota 4runner heater is blowing cold air
could be your heater core, um try checking the heater assembly in the dash, something may have broke so the heat isn't being switched over, and it is staying on cold. Regularly check the fluids in the motor and top up as needed
Nov 21, 2011 | 1990 Toyota 4Runner
Heater blows cold air
ok so the heater draws heat from the engine and if the engine dose not heat up anuff it will only blow cold air the reason the engine may not be getting worm is because the thermostat may be stuck open
Jan 27, 2011 | 1995 Ford Crown Victoria
NO heat.... Just is blowing cold air, never warms up. Do I just need to change the thermostat or is this going to be a bigger job? And where in the hell is the thermostat!?!?! (yeah, I have worked on allot...
Forget the Thermostat.
Start with no $.
Check Heater Core, leaks in rubber hoses ( they go to the firewall, should be hot when touch them (2) ) Coolant Level.
Nov 07, 2009 | 1999 Mitsubishi Galant
No heat air is blowing cold
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is worm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest to flush the heater core.
Oct 22, 2009 | 1998 Ford Taurus
MY 1998 FOR TARUS HEATER WILL NOT WORK.WAS DRIVING
It is most probably the problem with blend door or blend door actuator. But just in case I would suggest to follow the entire procedure:
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is warm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest flushing the heater core.
Oct 17, 2009 | 1998 Ford Taurus
Heater not working
Heater is blowing only cold air. both hoses for heater core are warm. what you think, main flap is stuck or is something else??
Hello there..Its two things..If your saying that the heater hoses are hot into the car,,either the blend dorr they call it thats what changes from cold to hot,the flap as you say,or the heater controller that controls it is bad..The dial on the dash that says cold to hot..Shut car down and listen for the flap to open and clse when you change it to hot to cold..If you hear it moving doesnt neccisarily mean that its working it could be broke from the flap and just spinning around or the flap its self is broke,or the heater controls are bad,,Hope this helps you and have a great day
Apr 05, 2009 | 1998 Audi A4
1992 honda accord ex 4 door heater not blowing
You may have a clogged heater core, leaking heating cores still provide heat.
Dec 04, 2008 | 1992 Honda Accord
Heating & Cooling Logo
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
