-   my typewriter will get stuck in the middle, or whereever..and will not move even if you push the mr....only if i turn if off and back on it moves to the far left..but not to the set margin....and after you type a couple lines it gets stuck again and will not return...-   val28570
Hit the margin release, morve the printhead to where you want the margin set and hit R MAR. This should reset the margin. You should also check to be sure there is no forien object in the machine preventing the printhead from moving to the right.
Doesn't hold left margin it will make a noise and margin moves over, sometimes to the far left and...
(More)
Doesn't hold left margin it will make a noise and margin moves over, sometimes to the far left and sometimes to the right to the middle of the carriage.
My Olympia Standard 210 won't print on the paper. The carriage moves and the striker hits leaving an...
(More)
My Olympia Standard 210 won't print on the paper. The carriage moves and the striker hits leaving an impression. However, the ribbon seems to sit too low and does not go up to meet the wheel keys. Prior to it stopping, it was making an awful noise and the carriage was moving up and down.
