Question about Bosch Kitchen Ranges
I replaced the the convection heating element on a Bosch HBL 455 AUC electric oven. The power trips when I turn on the upper oven (where the repair was made). The lower oven clock and lights are working fine. I must have crossed the wires. The are : White thinner guage, Green heavier gauge and Blue double wire heavier gauge. What is the correct order?
  • 2 more comments
  • tdusky Oct 20, 2008
    Wires are fine. I need the correct order the wires are attached to the heating element. Heating element has 3 terminals Top and bottom connect to the heating elements and the middle is a ground.
    The wires are white with a black stripe (thinner gauge). Blue double wire and green single wire.
    What is the correct order they attach to the heating element?
    White & Black stripe on the top.
    Blue in the middle (ground)
    Green on the bottom.
  • tdusky Oct 21, 2008
    I gave up on waiting for your advice. I made a list of the 9 possible combinations and started going threw them. My 4th try was the one, with white on the top, green in the middle and blue on the bottom. The oven would just trip off when I turned on the oven. I worked with the power off of course.
  • tdusky Oct 22, 2008
    I gave up waiting for an answer so I went forward with trial and error. I got it right on my 4th attempt. White on top, green in the middle(ground), and blue on the bottom. The problem now is the thermostat must have been damaged as the oven will keep heating up and not stay at the temperature set.
  • 958 Answers
After you have connected the wires in the correct order, now check the thermostat for continuity and should cutoff when you set it to a lower temp. if it will not cut off, then you need to replace the thermostat.
tnx 4 using fixya,
sorry for the delay in response. some of the experts are on a different time zone with you.
drcool
Posted on Oct 22, 2008
    Genius:
  • 1,011 Answers
    President:
  • 1,952 Answers
Dont risk u call service eletrician
Posted on Oct 20, 2008
    Genius:
  • 1,550 Answers
Here is the order of connection
white thinner gauge connect to the ground
blue double wire connect to the Top of heating element
green single wire connect to the Bottom of heating element .
You try this connection at your own risk .
Precaution: Better call a professional to do the connection as it is risky .
  • 905 Answers
How do you have them wires hooked up?
green is usually the ground on the metal of the device
  • 5 more comments
  • jason Oct 20, 2008
    does the element light up?
    do you have a volt meter?
    disconnect the element , and check to see where the AC power is comming from.
    it hard to diagnose a problem we cannot see , so we need more info
    green in the middle , the other two's order don't matter because its ac
    did you figure out those three wires?
    whats the model # ? so I can get the wiring diagram for it
    does it require 120v or 2 x 120v?
  • 77 Answers
Sounds like a short in one of the wires has a short in it where it was replaced. That would explain the power tripping. Search for any rips in the wire or where the wiring might come in contact with a sharp piece of metal.
I have a bosch Oven model HBL745A UC and the heating element at the back of the oven won't turn off.
Most likely part is the oven control board, it has relays on it . There is one stuck. IT is 2235 dollars to replace.
Dec 09, 2013 | Bosch HBL 745 Stainless Steel Electric...
Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
Tip
Common heating faults with Bosch HBL 455 Stainless Steel Electric double oven
For all Free appliance repair videos visit our VIDEOTUTORIALS 1, If the Bosch fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the BOSCH element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your BOSCH fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 455 Stainless Steel Electric...
Tip
Common heating faults with Bosch HBL 742 / HBL 746 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric Single...
700 series Bosch double convection ovens - Convection roast works, convection bake does not. Fast pre-heat does not work. We tried to reset ovens according to Bosch instruction manual guidelines, but it...
The good sign is that the motor works fine as do heaters. If the operator interface acknowledges feature selection by beeping or what have you, we can safely say the problem lies with the control board or relay.
Oct 02, 2009 | Bosch HBL 455 Stainless Steel Electric...
Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
Nov 08, 2008 | Bosch HBL 745 Stainless Steel Electric...
Bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
Jan 17, 2008 | Bosch HBL 745 Stainless Steel Electric...
Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
Kitchen Ranges Logo
176 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
