Question about Nikon N55 35mm Film Camera
Film advance Is there a feature on the N55 camera to advance the unused portion of the film? I would like to get them developed, but only used half the roll. Didn't want to snap off 12 more pics if I didn't have to. Thanks
    Problem Solver:
  • 14 Answers
No thers no more advanses but you can get them doveloped if there a surtin level
Posted on Oct 28, 2009
Film does not advance in my n55
is the film far enough to the right so it engages the sprockets ?
Sep 14, 2012 | Nikon N55 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Developing a film without opening the camera
Am i right in thinking the keystone is a old 8mm movie camera? Never had any experience with movie cameras, or developing their film- I'm goin to assume its like 35mm developing, apologies if this is completly useless advice.
I'm fairly certain you will not be able to develop film in camera (camera will end up pretty wet). If the problem you have is actually getting film out o the camera I'd suggest a changing bag- basically a light tight bag that you put the camera in with your developing tin (if your home developing) or canister if your using a lab, you then have to put your hands inside 2 holes either side and transfer your film from camera to developing container- blind.
I'd advise doing a couple practice runs first with some old unused film just to get the hang of it- it can be tricky.
Again I have no experience with 8mm film processing but I'd imagine the principles are similiar.
You can get hold of changing bags from most photographic retailers, and always follow instructions that came with your film.
Nov 05, 2009 | Cameras
Shutter speed
When you set the camera to "Full Manual" mode, you should be able to dial in your shutter speeds, for most film cameras, including the N55 30 Seconds is the slowest shutter speed. If your camera features a "Bulb" mode, then the shutter stays open as long as you are holding down the shutter release button.
Apr 12, 2009 | Nikon N55 35mm SLR Camera
New roll of film rewinds instead of advancing
Your camera has a faulty winding mechanism. It suppose to rewind in the end of the film when there are tension present but somehow the detecting system in your winding mechanism is detecting when the back door is closed. Remedy is replacing the clutch system within winding mechanism. Average repair runs about $90. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 21, 2009 | Nikon N55 35mm SLR Camera
Weird film exposures
check the developed film if the sproket holes are intact.
check your camera without film.
(1) open the back, do it as if you were taking pictures with different apartures/shutter speeds. If you can see the light coming in from the lens (no matter how little or how fast), your shutter and aparture diaphram are good.
if not, send it for service.
(2) if yes, check that the winding sproket wheel turns when you advance film.
(3) if it goes freely, try it again with finger pressing the sproket wheel. if this stops the wheel to turn, it is the gear/shaft inside disengaged. send it for service, of course.
(4) if your camera has a button for multiple exposure, ensure that it can be turned on/off as you wish, or you do not pressed it unnoticed.
good luck
pc-cook
Jan 19, 2008 | Nikon N55 35mm SLR Camera
Film doesn't develop
check your camer without film:
1). open the back, use different combinations of film speeds, shutter speeds and apartures. if you can see light coming in from the lens, no matter how little light and how fast.
2). check that film advances or not. if you camera detects film and loads automatically, insert any expired film cassette, or badly developed film and roll it back into cassette.
3). send it for service if either one or both gives you an answer of "N".
Jan 07, 2008 | Nikon N55 35mm SLR Camera
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
F--
Unlike other cameras that start at frame #1 after loading and count up as the film is used, the N55 advance the film to the last frame during the loading process. When loading is complete, the frame counter stops at the number of available frames on the roll (usually 24 or 36) and counts down as photos are taken. I know it sounds backwards but it actually makes a lot of sense to engineer it this way. After the last photo is taken (displays 1 on the counter), the camera automatically winds the end of the film into the cassette and the counter shows a blinking E. I am assuming that that is what is being displayed and not a blinking F. it it is an F, perhaps there is a problem with the LCD display? If so, it probably isn't worth having it repaired.
Jun 26, 2007 | Nikon N55 35mm Film Camera
Camera Rewinds New Roll of Film
Check the camera and the manual to see if there is a control to override the auto rewind; it may be set to rewind. Other than that, check Mikon's website for support info.
Jun 16, 2007 | Nikon N55 35mm SLR Camera
Nikon N55 35mm Film Camera Logo
82 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
