Question about Acer Aspire 3610 Notebook
DVD ROM won't open
The CD/DVD/ROM won't open. It makes a clicking sound, it is empty, and I've tried a paper clip. I don't want to force it.
    Novelist:
  • 67 Answers
Hi tashawenger,
I suggest that you power cycle your laptop. What I mean is that you shutdown the PC, disconnect the AC adapter and remove the battery and hold down the power button for about a minute. Then afterwards reconnect the battery, AC adapter and power on the system. And try to open the drive before it boots up inside Windows.
If this doesn't work, I suggest that you reseat the optical drive (DVDROM), what this means is that you remove or disconnect the drive from the computer then put it back in, then try it again to see if it works.
If that doesn't work, I suggest that you already try running the computer's diagnostics program to check and see if the drive itself passes the diags. You may have to replace the drive if all these fail, since it will now be considered a mechanical problem.
Hope this helps!
Peace! :)
Posted on Oct 20, 2008
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Cd won't open
On the face of the CD drawer there should be a small hole the size of a paper clip. Push a paper clip end into the hole, this should release the door and it will pop open.
May 08, 2012 | Everex IMPACT GC2500 PC Desktop
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
My benq dvd combo drive doesnt open how can i solve the problem
If you have a disk in there that you need and the paper clip option doesn't work then you will have to force it open, either way it's time to get a new drive.
note: there a hole by the button to open it with a paper clip
Feb 25, 2011 | BenQ CB523C CD-RW/DVD-ROM Combo Drive
Will not open?
Get a paper clip or something thin that will fit in the hole on the front panel of your burner.
push the paper clip in the hole and push till the tray opens.
Hope that helps
Dec 17, 2010 | Compaq (200356-001)...
My dell studio 1737 keeps making clicking sound and wont eject tried my computer, tried funtion key not doing anything please help
It sounds like your CD/DVD rom is stuck or damaged. If the drive is empty, this means that something is wrong with the drive itself.
Often, you can use a paperclip that has been bent straight to open this. insert the paper clip into the tiny hole on the door pannel of your CD/DVD drive and most of the time it should pop right open.
if it does not pop open right away, I have seen situations where the disc becomes lodged inside the case and will not allow the door to open at all. This may require you to take your laptop to a repair facility and explain the situation to them.
If you are feeling very confident, you can try to remove the CD rom drive from your laptop, remove the outer casing and see if you can dislodge the disc that way.
Aug 11, 2010 | Dell Studio 1737 Laptop
MY CD-DVD DOOR WILL NOT OPEN
This is sometimes cuased by either a faulty drive motor or even the Magnet which keeps the disc in place.
You can force eject the disc by taking a paper clip and straightening it out, then you insert the clip into the tiny hole under the CD tray and pressing it in firmly until the tray releases.
Mar 05, 2010 | Memorex (32023244) CD-RW/DVD-ROM Combo...
CD won't eject. I have tried the button on the drive and clicking the eject through the software. The light lights up and there is a whirring sound, but then nothing.
your cd rom tray is stuck inside may be due to a hardware error please take a paper clip and make it straight now insert this clip in a small hole located at the front panel of your cd rom drive..apply some pressure and the tray will be ejected/..
Thnx and i hope this helps
Please rate this solution
Jul 16, 2009 | Dell (0F146) Internal DVD Drive
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Problem with cd-r/dvd rom
does the light come on on the drive ? have you tried straightening a paper clip an putting it in to the little hole to push the draw open this may make it work if its stuck or try right clicking the drive in explorer and choosing eject from there
good luck
Jan 23, 2008 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Acer Aspire 3610 Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
