Question about Zanussi FJS1225W Front Load Washer
DOOR WONT OPEN
I went to start a wash and just as i did i forgot to put in a top and tried to open the door but it wouldnt open, i continued wash and at the end of the machine bleeped as normal to unload washing but i cannot now open door. I did another wash to see if it would release it but it still wont open. I have tried turning off the power and on again and this does nothing either. You hear the sound of the door lock unlocking at the end of the cycle but it seems the handle is jammed and wont open door, any ideas?
  • 3 more comments
  • bohlhead Mar 29, 2008
    my door wont open either, any suggestions?
  • Anonymous Mar 12, 2014
    Just 1 month old and after the wash the door wont open again, we tried the little green thing behind the bottom panel too
  • Anonymous Mar 17, 2014
    My wash stopped halfway through , and made 3 quick bleeps every few seconds, the door will not open , filter ok, it was towels so may be overload but I have tried turning the machine off at the mains for 10 min but nothing, I'm considering smashing the door in any other ideas lol
  • Anonymous Mar 26, 2014
    after a wash cycle the door remains locked and i have to manually turn off the power at the wall socket for the door to open
    Problem Solver:
  • 8 Answers
Hi. Try un-pluging machine,take off top lid slide your hand down between casing and drum until you find lock, then try flicking door casp while trying to open door gentely. when open replace door lock before using again.
Slim jim
Posted on Nov 26, 2007
I'm afraid I don't have a solution, just the same problem. Exactly this has just happened to me and I don't know what to do. Calling out an engineer will be too expensive and in the mean time, I can't do any washing. Have you had any success yet?
Posted on Jul 12, 2006
Dishlex DX203SX Dishwasher door wont close
check the lock maybe it flipped shut lock maybe getting stiff from steam?
Feb 07, 2015 | Dishwashers
Door wont open on Hotpoint WM51 First Edition
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
In your case you might have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Apr 25, 2013 | Washing Machines
Dryer wouldnt turn on its saying door is open
most of the time. its the door switch that causes this. if door is closed and it does not start, its the door switch. try this! unplug power, remove the door switch, hook the wires from switch together. this will make a complete curcuit.put black tape on wires so it wont short out. plug back in. it should work, if it runs ok door switch is bad. good-day !
Mar 29, 2012 | Frigidaire Dryers
Hi yesterday the door of the washing machine hotpoint aquarius 1000 wouldnt open. i turned it off took the top off and undid the catch with my finger. Now the door opens fine but its not getting any power....
Mike, you probably have a failed interlock...The latch which locks the door during the wash. It has an internal switch...That's why the machine wont start till the door is closed.....Most probable answer is to replace the interlock...If you want to do it yourself, you'll have to undo and refit the door seal...Or...It's not a big job for a tech...Good luck....Nomess
May 17, 2010 | Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Sep 15, 2009 | LG WD-16115FD Front Load Washer
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
917 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
