Question about KitchenAid KESC307 Electric Kitchen Range
KITCHENAID KESC307HBS SLIDE IN RANGE
The oven is not heating properly. I have compared the time needed to get the oven to heat to temperature and it is taking 3 times as long as it should (I know someone who has this same oven and we compared heating times). An electrician checked to see if it is drawing the correct amount of power and it is NOT. What would cause the oven to not be drawing the correct amount of power? Is this due to a computer malfunction with the oven? If so, what part and how costly.
    President:
  • KitchenAid Master
  • 2,651 Answers
Possible bad control, but also might be a bad elemnt ( hidden under the oven floor depending on issue depends on cost of repair, your gonna have to get it looked at , call an authorized company for possible extended part warr's if they still apply , generally 5 yrs on electronic parts and elemnets
Posted on Oct 26, 2008
Oven shuts down while baking
thermostat my be brokenit thinks its hot so it shuts the heat off....
Apr 21, 2014 | KitchenAid KERS807SSS Electric Kitchen...
Kitchen Aid Gas Range.Convection mode fan does not come on.Glow bare works,as well as the gas element.Flame is the proper colour.Could it be the oven sensor?Model nos.ykgst307hw5
Does the oven heat to the proper temperature and hold it there or does it not heat at all? I could not tell from your description of the problem.
Regards,Richard
Nov 08, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
My kitchenaid range KESC307HBS door will not unlock code F5 E3
Hi ad welcome to FixYa, I am Kelly
Here is the service manual:
http://appliancedigest.com/index.php?/files/file/242-whirlpool-kac-34-kitchenaid-self-cleaning-slide-in-electric-range-service-manual You have to join the site to get the manual but of all sites this one is a gold mine of information. I am sending this link now and will respond again after my almost 3 hour manual download of the manual. I have to read the manaul myself before responding. My intial thoughts are the following: Possible door lock failure, an oven sensor has failed or a high limit thermostat has failed. I will resond with the code F5 E3 data after the manual completes. Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | KitchenAid KESC307 Electric Kitchen Range
Convection stopped working a couple of months ago, now regular oven does not come up to proper temperature, top element is red bottom element is not
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 12, 2010 | KitchenAid KESC307 Electric Kitchen Range
Will not heat up
1. Make sure the controls are set properly,that the oven selector switch is set correctly and that the temperature
switch is set to the desired temperature where applicable,make sure the oven timer is set to manual.
2. If nothing else on the Range,Oven or Cooktop is working then
1. Check the circuit breaker or fuse.
2. Test for power.
3. Test the oven elements.
4. Test the oven thermostat.
5. Test the oven selector switch.
Feb 03, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KitchenAid Electric Range Model KESC307HB56
Electronic control has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method next time.
Jun 12, 2008 | KitchenAid KESC307 Electric Kitchen Range
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Sep 07, 2006 | KitchenAid KERC507 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
189 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
