Question about Sharp Office Equipment & Supplies
Sharp copier model #AL-1631
My copier won't pick up paper -- have cleaned the barrels and wondered if there is anything else I can do. Where do I find a service company for it?
  • 145 Answers
Where are you located?
Posted on Oct 21, 2008
I have a Sharp AL-1631 Copier. The 'P' Light comes on indicating a paper jam, however when I open the machine there is no paper jammed. Any suggestions?
Check the dash and see if the lower tray is selected or the by-pass tray on the side. If the side tray is selected change to the bottom tray.
May 13, 2011 | Sharp AL 1631 Copier
When copying from the SPF the paper misfeeds. It starts through but the goes crooked.
You need to adjust the SPF paper size knob to fit your size of paper freely. Make sure that area is clean or you can wipe with a clean damp cloth the picking roller which is located there.
Dec 23, 2009 | Sharp AL 1631 Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 bottom paper feed will not pick up paper.
A few things could be the problem.
  1. The paper in tray could be damaged
  2. The drawer separator pawls (metal taps on the right side of tray where paper touches)
  3. Paper backstop not in or in wrong spot (green plastic piece at back of paper)
  4. Feed tires are worn or dirty
Does the copier try and feed from tray 2? If it tries but the paper doesn't leave the try look and see if there is a dark mark on the page (top middle towards the right). If so then most likely the feed tire is worn.
Oct 12, 2009 | Sharp AL 1631 Copier
Flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Sep 27, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Aug 09, 2009 | Sharp AL 1631 Copier
Sharp AL-1631
there is severl thing this could be 1. paper feed cluch need cleaned 2-bypayss roller lift arm need removed, 3-or the drum unit need clened out . all thses thing can be dones easilly by a sharp tech about $120 should do it. note this is the only model of copier left that you can refill the toner unit for $6 & drum for $15 ( id keep it )
Mar 10, 2009 | Sharp AL 1631 Copier
1/8 black lines on Sharp AL-1631 copier
Have you cleaned the narrow glass next to the platen where the originals are scanned across when using the auto feeder?
Feb 17, 2009 | Sharp AL 1631 Copier
Jammed paper
where is it jamming ? pick up, on the side in the fuser where it gets hot???
Jul 17, 2008 | Sharp AL 1631 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
