Question about Nokia N70 Cellular Phone
DISPLAY NOT VISUAL
POWER ON BUT NO DISPLAY
  • Anonymous Oct 23, 2008
    my
    cell phone is not on
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 57 Answers
Formating your phone may fix the problem. Heres how you can format your phone
Heres how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
before formating make sure that you copy all your contacts, messages, calendar, and each and everything in your memory card. And dont forget to remove your memory card and fully charge you phone before formating.
Posted on Oct 22, 2008
No visual display
It could be a loose connection, bad driver ic, or bad display, or something else. You would likely have to troubleshoot at the component level.
Oct 15, 2014 | Ivoclar Vivadent Odyssey 2.4G Odyssey 2.4G...
The phone is working but the screen is black
Remove battery if possible or power down the device. Replace battery and power on, if you hear the the device working yet there is no visual display it sounds as if the display has gone bad. Check to see if it's still under mfg warranty, they are typically one year warranties.
Jul 31, 2013 | Android Cell Phones
Loss of visual display on my hands free kit
It will require a power cycle, you will need to unplug the Parrot kit and wait a few minutes, then try again. If you have a remote for your kit then you must have a MKi kit which can be updated via the USB port, details are all on the Parrot support web site. You can also view a list of accredited Parrot engineers on their web site if you would prefer someone to look at it.
Nov 26, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
My computer boots up but no visual display on the monitor.
Possible that the display driver section is faulty, failure of supply to the driver, failure off the connecting link or a possible power supply fault , all of these needs a closer check on the main board.
Mar 30, 2011 | IBM Computers & Internet
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
Mar 03, 2010 | NAD C521 CD Player
Power is there but no visual display
does the unit beep at all? Is the fuse ok in the units' power cord? Check these out. If the fuse is bad you can replace it with a 2 amp fuse from an auto parts store.
Jan 08, 2010 | SRT-35R Radar Detector
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Menu display intermitent
display is disclosed which produces multiple visual displays in an intermittent manner which includes a display housing having a perimeter wall which is transparent during visual display and is an opaque mirror between visual displays. The perimeter wall of the display housing is a composite structure which preferably includes a transparent cylindrical substrate which is coated with an optical film and an opaque mask which defines display windows. Multiple visual displays are produced by a rotating display base which carries rows of rotating display elements. Preferably, the display elements are elongated triangular elements having three image faces which bear images which create the visual displays. The triangular display elements are arranged in a triangular configuration wherein the rows intersect one another at acute angles and are carried by the rotating base. The rotating base includes three display positions and each of the triangular elements includes three display positions. A stationary observer would see nine different visual displays and may see themselves mirrored in between and during the changes of visual displays. The perimeter wall of the display housing becomes transparent as the triangular display elements are backlit along their entire length by elongated fluorescent or neon light tubes. When the light tubes are off, the cylindrical display housing is an opaque mirror, preferably, about its entire periphery and height. Other embodiments of the invention include a single row of triangular display elements, and a rotating display base which includes display faces consisting of only a single display element.
Feb 25, 2008 | Solarism LM-1730 (Black) 17 in. Flat Panel...
Nokia N70 Cellular Phone Logo
74 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
