When I power up my computer, after it asks if you want to interrupt normal setup, it goes to a second screen which displays a computer and lock icon. Normally, I just get the lock icon for which I enter my password. This time, I also get a computer icon displayed to the left of the lock icon. I try to use the password but it comes back with an X for failed. What is it looking for?
SOURCE: Ibm thinkpad t40
Hi tdarrin,
Try to repair your operating system using your current version of windows OP. Possible some destructive program black the windows startup not to continue.
Hope this will be helpful to you. Please let me know if you need more help.
Best Regards,
Philip
SOURCE: laptop is locked out
This works great
Forgotten Power-on password
If the Power-on password is forgotten
and the Supervisor password is known,
simply go into the ThinkPad BIOS setup
utility and reset the Power-on password,
otherwise try the following:
Turn off the computer.
Remove the battery pack.
Remove the backup battery. This is
located under the battery.
Turn on the computer and wait until the
POST ends. After the POST ends, the
password prompt does not appear. The POP
has been removed.
Reinstall the backup battery and the
battery pack.
Note: Some ThinkPad systems have the
ability to reset the Power-on passwords
in the ThinkPad BIOS setup utility if a
Supervisor password has been set.
SOURCE: IBM T21 NEW MOTHERBOARD PASSWORD PROBLEM
Break BIOS Password
A user may also put a BIOS password preventing you to even enter the system but if you wish to access the system do not worry we you can still do it. However, I only recommend this trick for your own personal use.
What is BIOS?
Bios stands for Basic Input Output System and is a firmware code run by a PC when first powered on, which is a type of boot loader. The primary function of the BIOS is to identify and initialize system component hardware (such as the video display card, hard disk, and floppy).
How to Break a BIOS Password?
The following steps work absolutely fine for a Desktop and are the easiest of all.
Steps:
• Shut down the computer and take out all the plugs connected to electricity.
• Open up the CPU cabinet and locate the CMOS battery on the motherboard (it will be a silver circular battery just like a button cell).
Remove the battery and keep it out for some 2-3 minutes as this will flush out the CMOS memory which stores the BIOS password and all other configurations.
• Now place the battery back and start the computer normally.
Steps for Laptop:
• Open up the BIOS at the time of booting.
• There are some backdoor passwords which the manufacturing company had set that will be accepted by the BIOS. You will just need to know the make of your BIOS. Try out the passwords from these lists.
List of Award BIOS backdoor passwords:
BIOSTAR, AWARD_SW, AWARD SW, AWARD PW, CONDO, LKWPETER, J262, 01322222
List of AMI BIOS backdoor passwords:
AMI, AAAMMMIII, BIOS, PASSWORD, A.M.I., CONDO
List of PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
You may also want to try this utility CmosPwd 4.8
SOURCE: Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Attach a USB connector to the iPod and plug it into a USB connection on a computer for power, or into a stand alone USB charger plugged into a power strip for electrical power.
Pick up the iPod. Move the "Hold" switch at the top of the iPod to the "Locked" position so that an orange color appears by the switch. Return the switch to the "Unlocked" position.
Repeat this process. Press and hold the "Home" button and the button at the top right corner together if using a fifth generation iPod, iPod Nano, iPod Mini or iPod with a click wheel. Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod.
Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo.
Release the buttons. Wait as the iPod resets itself and turns itself back on.
or
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
hope this helps
