Question about Seiko Kinetic watch
Seiko Kinetic Watch model 8D0557
After wearing my watch for 12-14 hours daily it goes dead overnight. I have owned this watch for close to 10 years and have been satisfied. help.
  • Anonymous Apr 29, 2009
    I have the same problem with a Seiko. I just called a jeweler who said he woudl have to send it back. I told him the symptoms and he said it may just be the battery. I paln to look on websites to see if this battery can be replaced easily or not.
    Scholar:
  • 110 Answers
For sure it is time to replace that old capacitor and replace it with the latest solution that uses a Lithium Ion battery. Find a good experienced repair person to do this for you. I do this daily and I am a Certified Master Horologist/watch repairman.. Ron at TimelyWatchRepair.com
Posted on Dec 12, 2009
    Problem Solver:
  • 17 Answers
The latest 3rd generation batteries for the Seiko Kinetic are not only Lithium but Titanium Lithium. They will last approximately 20 years.
There are videos on YouTube on how to change your battery. There are also at least 4 web sites I have found with extensive photos and text describing how to replace the battery.
I am simply a retired Physician but I have replaced over 100 Ti-Li-Ion batteries for other people, without problems. Just use common sense: plastic tweezers instead of metal, be certain not to touch the - and + terminals at the same time, etc.
You can expect to pay about 20 dollars just for the battery. Jewelers are getting outrageous fees for replacing the battery in a Seiko Kinetic, considering how easy it is.
Be very careful because jewelers have the old Lithium batteries in stock and they are putting those into watches instead of being ethical and installing the newest Titanium batteries.
The new Titanium batteries have advantages; for example an M62 or M63 model will keep stored energy for 6 months without ever being worn. I am testing the M42 and M43 models now, and expect they will give 2 to 3 months reserve power if just left sitting.
I do caution you against letting your Seiko Kinetic battery run down completely. That will degrade any Lithium battery, watch, camera, etc. If your battery gets close to exhaustion be certain to recharge it.
I hope this helps.
Posted on Apr 23, 2013
Seiko watch self winding mechanism does not keep watch wound. I have to set the watch unless i wear it 24-7
The issue reported is not about how to set the watch, it is about the fact that it stops if it us not worn continually. This could be an indicator of the movement needing to be serviced. Automatic watches such as yours need to be serviced regularly, every 3-5 years or as needed by such indications. My recommendation is to see a Certified Master Horologist to test the watch on the timing machine.
When serviced, there should be approximately a 45 hour power reserve when fully wound.
Thanks for rating! http://www.watchandpen.com/id76.html
Sep 22, 2013 | Seiko Kinetic watch
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
May 23, 2011 | Seiko Kinetic watch
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
My 5 year old Seiko kinetic (divers') watch: beyond shaking, is there a way to wind it? I used to be able to press the power button and see the second hand advance 20 seconds. Now I never have enough...
I am going to make an assumption or two. One is you wear your watch regularly. At least every other day. Two is you are not sedentary. Try wearing the watch for three days. If the power indicator doesn't read at least 15 to 20 you have a bad cell (capacitor). If it does charge up to 15 to 20 then see if it lasts very long. Should last a couple weeks or more. If not then you still have the same problem. You can also go to a watchmaker and he will have a piece of equipment that can charge your cell in 3 1/2 hours. Then if the cell goes dead rapidly he/she will replace it. Should cost around 50 or less.
Mar 13, 2011 | Seiko Kinetic watch
My seiko is keeping good time but the second hand jumps two seconds then hesitates for what seems to be a second then skips two seconds again
There are three solutions for this problem, contingent upon the model:
With both instances, this is a power saving / low charge / low battery feature of the timepiece.
1) Is your Seiko watch a Kinetic / Solar model? If so, your watch contains a capacitor. The capacitor may be bad, OR if you have not been wearing it on as regular a basis, wind the watch (Kinetic) vigorously for 5 minutes, and if the second hand returns to normal function, the capacitor is most likely fine. If is is a Solar model, expose it to sunlight for 4-6 hours or incandescent light for 24 hours and see if this resolves the problem.
2) Else: if this is a standard battery operated watch, take your watch to an authorized Seiko repair center, or Certified Master Horologist. Make sure that the Seiko Repair Center is using Seiko batteries, else make sure they are installing Energizer only - these two batteries will not leak in your movement. Avoid other batteries at all cost, many of them will leak and ruin your movement.
3). If these solutions do not work, and you have not had your watch serviced in the last 3 to 5 years, you need to service the movement. See the aforementioned parties to begin the process.
4) If your watch is water resistant, and/or you plan on wearing it in the water, make sure to have your watch water tested by the appropriate aforementioned professional to ensure it will withstand proper dynamic and static pressure at the appropriate depths.
Feb 04, 2011 | Watches
My Seiko Kinetic winds down in one week after weaking a years and is not recharging to run after one day of wearing.
It sounds like that it is time to replace the capacitor with a new Lithium Ion battery. Send it to Timelywatchrepair.com. Go to this web sight
Dec 29, 2009 | Seiko Kinetic watch
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
Watch will not stay running
Most likely time to replace the capacitor with a new Lithium Ion battery. This is the correct way to fix this problem. No one uses the old capacitors any more. I do this repair daily as a Certified Master Horologist/watch repair man. Ron at TimelyWatchRepair.com
Dec 25, 2008 | Seiko Kinetic watch
Seiko Kinetic watch Logo
399 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
