Question about RCA RP2520 Personal CD Player
Not reading inserted disc
My portable CD player is powering on, but after inserting my CD it shows " rd disc ".i kept it la that for a change at all. do help me.....thanx in advance
0 characters
1 Points
I don't have an operations manual for this portable compact disc player PC308B. Where can I get one?
Hi John,
Click this LINK.
Click "Download the Document".
Enter your email add
Enter the confimation no.
Click "Download".
This is a safe website, I used it personally.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 14, 2011 | GPX PC308B Personal CD Player
Where is the power button?
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you with your question. You want to know where the power button is on the Memorex MD6451R Personal CD Player? Well to answer your question, the power button is Play/Pause button. Insert a CD into the compartment, close the top and press the Play/Pause button (whether on the CD player or the wired inline remote). I hope this turns on your CD player and thank you for choosing FixYa to answer your question. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 28, 2011 | Memorex MD6451R Personal CD Player
I had bought a regular cd from hmv with music on it & when i put the cd in the cd player,it wont play & reads NO DISC also does not reads the amount of music on the cd,why does it give me this...
1. Check that the disc is free of scratches and dirt or dust. If the disk is dusty, use a soft, lint-free cloth and wipe the disk gently, using straight strokes from the center of the disc to the outer edge.
2. Make sure that you are inserting the disk with the plain, reflective side down.
2. Try listening to another CD (not burned) that you have purchased. If the other cd is giving you the same error message, return the cd player to the store, because it is defective.
3. Ensure that the disc you are using is not a DVD disc. It is easy to confuse the two.
Hope that helps! Good Luck!
Mar 13, 2011 | Panasonic SL-SX420 Personal CD Player
Definitely you must claim for the refund or the service warranty on your set from the people you have bought this from. But first of all please check if you have placed the batteries in the right direction to get teh display, if so have you inserted the disc correctly , a good one, and checked if it played. if it turns and stops clean the head and try. if not you must proceed to get your claim. good luck good day
May 08, 2010 | Jwin JX-CD588 Personal CD Player
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
My Sony D808K portable CD player will not play a CD. When the door is shut the player should turn the CD and show info on the LCD display, but that doesn't happen. If I press the play button, it tries to...
It's dead. Mine did the same thing, but I noticed also that the disc never spun up fast enough to be read successfully. I'm guessing that the motor just lost its oomph. I imagine that one way or another it's fixable, but with portables so cheap and a player this old not being able to read anything but manufactured CDs, i.e., no CD-R, CD-RW, etc., it's not worth it. And mine was old enough to vote! :)
Jul 30, 2009 | Sony Personal CD Players
Jack is broken on portable CD player
Mystical Chicken, all that needs to be done is to open up your player and re-flow the solder connection where the ac adapter goes. It is a fairly simple task, given you have used a soldering iron before. If not, just send it to me and I'll fix it.
Jul 06, 2008 | Personal CD Players
CD player not turning
The laser is damaged/worn out. It would be cheaper to purchase a whole new unit, instead of repairing that one.
Sep 20, 2007 | Personal CD Players
Are you using the car adapter or batteries? Are the batteries good? Are the CD's clean? Have you tried the CD's in another player? Do they work there? Maybe the lens on the laser needs cleaned.
Feb 15, 2007 | Coby MPCD950 Personal CD Player
RCA RP2520 Personal CD Player Logo
16 people viewed this question
Top RCA Personal CD Players Experts
Todd Zettlemoyer
Todd Zettlemoyer
Are you a RCA Personal CD Player Expert? Answer questions, earn points and help others
