Question about Lands Phones
Whole house ringing when cordless phone is used
Motorola ME4052-4 I have 4 handsets with one connected to a phone socket, each base is connected to the electricity supply within the house. When I pick up the phone which is connected to the phone socket all is fine. When I pick up one of the other three, every base unit rings constantly. The phones used to work fine, this is a more recent problem.
  • 4 more comments
  • Anonymous Oct 22, 2008
    ONE PHONE RINGS THEN THEY ALL START RINGING
  • fedup04 Dec 03, 2008
    I have the same problem when making or receiving calls on any handset on my Motorola 4052 quad dect phone set. What is the solution ? Fedup
  • Anonymous Dec 17, 2008
    I have the same problem. The quad pack used to work fine but now all the phones/base stations ring together when a call is made. It doesn't always happen and sometimes stops seemingly randomly.
  • dutees Feb 04, 2009
    I have a motorola quad set and this is happening to me as well. It has been doing this for about 3 months, the sets are about 1+1/2 yrs old. There does not seem to be any consistent scenario to cause this and sometimes I can make / receive calls with no problem. But when it happens, boy is it annoying. Hope that someone soon finds the magical answer because I am thinking of getting a new set of phones to hopefully stop this but I don't want this problem to re-occur if I do. Regards,
  • filippobart Mar 05, 2009
    I have the same problem with a double phone set. And it is a recent problem, before they used to work fine.
  • Anonymous May 13, 2009
    Same problem... reset everything put the problem is still there
Try deleting all headsets using primary headset (marked with no.1): 4-base/8-deregister/default pin '0000' and register them again using each headset (3-headset/8-register/same pin). it worked for me.
Posted on Mar 27, 2010
Tip
Connecting extra handsets to main base
Call your phone, while it is ringing put your extra handsets on the main base. I did this and they started to ring when on the base and they worked after that. You may not need to call the main line, only put the extra handsets on the main base to get them connected but I didn't try this so I don't know.
on Oct 18, 2008 | Uniden Cordless Phone
Motorola Cordless: not ringing when off base
Is the base ringing when the phone is on base or the phone ad well? Have you turned up the volume while not in a call to ensure handset ringer is on?
http://www.motorolacordless.us/
Mark
Motorola Support
Feb 09, 2014 | Motorola Lands Phones
I have the Dect 1683 with three handsets. We had a hurricane and the power went out and not all three handsets read "Searching" and I get no dial tone. When the phone rings it rings but you...
Hello
Just unplug the base unit from AC wall power socket for a while, say for about 5 minutes or so, replugh the base unit to power socket again. Place each handset on it and synchronise it with the base unit. As you put it on, you will hear a beep sound. Now the ahndset ahs been synchronised with base unit. Do this for the other two handsets. OK.
Aug 30, 2011 | Uniden DECT 6.0 Cordless Telephone...
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Oct 19, 2008 | Vtech Cordless 6041 Phone
Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Oct 06, 2008 | Uniden Cordless Phone
My handset won't charge
Try charging it in a different cradle if you have more than one handset.  This has happened to me where a particular base will not charge a particular phone.  Once charged elsewhere the problem resolved.
Feb 14, 2008 | Motorola Mobility MD671 Cordless Phone
No Dial Tone
I have found this free link on BT site for you
http://www.shop.bt.com/content/uni2/documentation/498n/025455.pdf
If the second handset works ok on the base and the first handset doesn't, then you are right...the fault lies with the first handset. There are batteries ( special type ) in the handset, it sound as if either the batteries are dead, or not charged ( try charging them for 12 hours on the good base station ) or the connection is bad.
May 08, 2007 | British Telecom Synergy 2110 Cordless...
Lands Phones Logo
390 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
