Question about Sony NW-HD5H (30 GB) MP3 Player
Connectint tp pc
Player is constantly trying to connect to pc. Battery has been removed several times but no joy. Connecting to pc when charger conected or on its own. Cannot get out of it. Player will work when connected to sonic stage via the sonic stage software. Help!
5 Suggested Answers
  • 91 Answers
SOURCE: software
You maybe able to use Windows Media Player 10 or 11, if you want to try well connect your mp3 player to the computer now wait a few seconds then go to Windows Media Player ( if your using windows media player 10 i recommend you to update to media player 11 for better results but if not when your on Windows Meda Player look for a link called "Sync" when you've found it click on that.
Now your on "Sync" if should have found your mp3 player now just drag and drop music you wish to have on your mp3 player on the side panel where it's got a little image of an mp3 player.
Once you've added the music, safely remove the mp3 player like you normally would then see if the music has successfully tranfered.
Here is the new Windows Media Player 11 if you haven't got it already.
Good luck. Hope my solution was helpful.
Posted on Oct 26, 2007
SOURCE: sony nwz-e436f frozen on connecting screen
Hey! We've had a similar dilemma, and we solved it by connecting walkman to computer, then going into 'device manager' uninstalling the walkman, then remove it from usb port and re-connect it.
The computer will then 'recognize new hardware' and automatically re-install the walkman. Good as new!
Hope this helps!
Posted on Jun 01, 2009
SOURCE: Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
Posted on Sep 10, 2009
  • 803 Answers
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Posted on Oct 31, 2009
  • 455 Answers
SOURCE: i want to add video
The NWZ-S616F Walkman Player is not transferring the music using the SonicStage Software. Sony old Walkman player was using the SonicStage Software for transferring the files. You can use Windows Media Player 11 or higher, Media Manager for Walkman, Content Transfer Software or Windows Explorer for transferring the files to the Player.
Click here and select the operating System to download the Software for transferring the files.
Thanks for using FixYa.
Posted on May 07, 2011
0 characters
1 Points
Just rediscovered after 10 years but minus charger and headphones...
It is possible battery has totally exhausted and on connecting PC consumed total current of port. Try to charge device for a long time.
Apr 03, 2016 | Archos Gmini XS202 MP3 Player
Hello i have a mp4 media player, my problem is that no turn on the batery is ok when i put the select in ON the media player no turn on i try to connect in to the pc but no conected to can you help me
Good morning, afternoon, evening or night; whatever time of day you are viewing this. Thank you for choosing FixYa to solve your problem. Your problem is that your MP4 player will not come on, even when you connect it to your PC? Well, you should try recharging your battery. There are two ways you can charge this device using your USB cable. The first way is by connecting the USB cable to your PC. Charging will take 8 hours by this method. The second way is connecting the USB cable to the wall charger that was supplied with your media player. If you had a problem connecting to your PC, you should try charging via the wall charger. Charging is much faster this way than using a computer. If charging doesn't turn your device back on, your battery may be defective. If that's the case, you'll need to get the battery or your media player replaced. Hope it's just a recharge that's needed. Thank you for choosing FixYa as your one-stop solution spot for your problems. Have a good day, afternoon, evening or night; whatever time of day you are viewing this. Come back and visit our site again whenever you need assistance!
Apr 29, 2011 | Visual Land VL-853 Digital Media Player
Dear sir, my zen creative i pod is freezes on zen screen, it also does't connecting with my pc. so plz guide me how to solve my problem.
Flip the "Hold" switch that's on either one of the sides or the top of the MP3 player to "OFF." Press "Play" or any other button to try to unfreeze the player.
Leave the MP3 player on in its frozen state until the player's battery completely dies. Depending on the amount of life left on the battery, this could take several hours.
Connect the MP3 player (using the universal serial bus or USB cord) to an MP3 charger or a computer. Turn the computer on. Leave the MP3 player charging for 30 minutes to 1 hour.
Connect the MP3 player to a computer using the USB cord. Open the software media program that syncs with that particular MP3 player. Then, click on the "Sync Player" or "Sync" link or tab, depending on the program you're using. Wait ten seconds, and then try to use the MP3 player. Disconnect the player from the computer if it's still frozen.
Press "Reset" on the MP3 player. Depending on the MP3 player you own, the button may be easy to find or incredibly small. With tiny buttons, a tack, needle or similar item is needed for pushing. Press and hold the "Reset" button for approximately seven to ten seconds. The player should unfreeze and reset. Some data, such as music, may be removed from the MP3 player during this process.
Sep 03, 2010 | Creative Labs ZEN Vision:M Digital Media...
Sony nwz-e436f frozen on connecting screen
Hope this helps!
May 20, 2009 | Sony NWZ-E436F MP3 Player
Archos 605wifi not switching on
Hi, my Archos 605 160GB is doing the same, Sorry to say the battery has gone.
2 options
1. Back to Archos
2. Replace the battery yourself I ordered mine from HK from the web site BatteryUpgrade. co. uk for about £24 - If you search on Utube there is a video showing you how to change the battery on smaller 605's
Jan 09, 2009 | Archos 605 WiFi Digital Media Player
Recharge Zen without computer
Use an usb charger or just go to creative store you can get the charger for your player
Some of the motoralla phones have the chargers identicall to ur players charger
Dec 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
Philips mp3 player
If you have tried the reset, then it could be one of the following:
1. faulty charger - Need to replace it
2. Faulty/failing battery - Need to replace it
3. Faulty contacts / cable - Need to replace the cable or service the unit for faulty contacts.
If you are able to switch on the unit, try the following:
Please follow the steps below to recover and upgrade your player with the latest firmware:
  1. Make sure that your computer is online and connecting to the Internet.
  2. Launch the Firmware Manager at Start->Programs->Philips Firmware Manager on your PC.
  3. Connect your GoGear to the computer while pressing & holding the 070119082257_17362.gif(>||) key until the Firmware Manager recognize the GoGear and a dialogue boxpop up in recover mode.** If you failed going to recovery mode, “pleaseconnect the device in recovery mode” is displayed please repeat step 1to step 3.
  4. Click Start to confirm and start recovering the unit to its factory setting.
    IMPORTANT: All music & content of your GoGear Player will be erased once the factory setting is restored.
  5. Follow all screen instructions and click Finish at the end to complete the recovery.
  6. The Firmware manager will close automatically once the success message is displayed.
  7. You can now remove your player and start using it again.
You could also try to manually upgrade the firmware and see if that helps...
Oct 12, 2008 | MP3 & Digital Media Players
Screen frozen player will not do anything
Have you tried:
1) pressing and holding the reset button (little hole on the bottom right of the player" for 10 seconds?
2) removing the battery for 10 seconds?
3) connecting it to your PC with the battery removed?
4) connecting it to your PC and pressing the reset button for 10 seconds?
Jul 23, 2008 | Insignia NS-DV2G MP3 Player
Charging problem
Hello lil ronaldo,
It sounds like the internal battery pack may be failing. The rechargeable batteries commonly used in MP3 players last a long time but they do eventually fail and when that happens the battery will fail to properly hold a charge. It may come up to full voltage when you attempt to charge it but will quickly run out of power when removed from the charger. This sounds like what is happening based on your description.
I would recommend contacting Samsung to get battery replacement service. You can call them at 1-800-SAMSUNG (726-7864) or use their online service request tool. If the unit is outside of the original manufacturer's warranty there will probably be a charge for the service.
Best Regards,
"Go Ahead. Use Us."
Jul 15, 2008 | Samsung Yepp YP-P2 Digital Media Player
Connect to PC and use device manager to repair
If you have the software conect the device to the computer; press volumen + with on/off switch at same time; then press volumen - anh hold it. The software recognice the device and you can update the firmware or repair it.
Aug 20, 2007 | Philips GoGear HDD6330 MP3 Player
Sony NW-HD5H (30 GB) MP3 Player Logo
Top Sony MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Sony MP3 and Digital Media Player Expert? Answer questions, earn points and help others
